Engine swap
Old Dec 8, 2018 | 10:48 AM
C3ForLife1968's Avatar
C3ForLife1968
Default Engine swap
I am going to restore my dads 1968 Corvette, but i dont know much about stuff. I am wondering if a 383 engine will fit in it. It was originally a 427 and has later been swapped for a 350. I want to put a 383 in it, but i dont know if it will fit with a long waterpump. Can anyone help me? Thanks
Old Dec 8, 2018 | 11:03 AM
jackson's Avatar
jackson
Yes 383 fits same as 350. If the pump on 350 fits then use a pump just like it on 383. Long pump will not fit
Old Dec 8, 2018 | 11:52 AM
derekderek's Avatar
derekderek
Exhausts, pumps, brackets, mounts, intake will all swap from the 350. Unless it is aluminum heads with raised exhaust ports there is no external diff between 383 and any stock gen 1 350. Did your dad do the 350 conversion? And if so is the 427 stuff stored? If so, going back to big block should be considered.
Old Dec 8, 2018 | 11:53 AM
C3ForLife1968
He did not swap the engine. He bought it with the 350.
Old Dec 8, 2018 | 11:56 AM
dmaxx3500's Avatar
dmaxx3500
put a 427/454 back in it
Old Dec 8, 2018 | 11:58 AM
C3ForLife1968
Would be awsome, but i dont think it will be an option. It will cost more, and since i live in Norway, fuel is really expencive. And there are lots of fees for having a big engine
Old Dec 8, 2018 | 12:53 PM
Peterbuilt's Avatar
Peterbuilt
The water pump is Corvette only so measure the old one to compare the size.
Old Dec 8, 2018 | 01:54 PM
jackson's Avatar
jackson
What Vehicle did the Norway 350 come from? A vette, a truck, a caprice or what? Does it have a Long pump now? Does its pump match dimensions Peterbuilt supplied above?
Just as sbc 73 Vette pump is unique, so are the 73 Vette combinations of sbc brackets & pulleys which are configured to fit sbc vette pump only.
Big Block Vette brackets & pulleys combo are Not configured to fit small block.
Old Dec 8, 2018 | 05:00 PM
derekderek's Avatar
derekderek
Whatever setup you had on your 350 will work on any 350/383 you replace it with. Just watch out for a one piece seal motor. That would require a new flywheel. And oil pan. And most of the one-piece Motors don't have fuel pump mounts.
Old Dec 8, 2018 | 06:18 PM
jb78L-82's Avatar
jb78L-82
A strong 383 crate with 450 Gross HP/450 TQ will be really nice and well balanced to boot. Pretty much the best of all worlds for your C3.....
Old Dec 8, 2018 | 06:20 PM
C3ForLife1968
Nice can anyone link me a complete 383 without a flexplate. Really hard to find and i would really appriciate it if anyone could fine one thanks
Old Dec 8, 2018 | 06:26 PM
jb78L-82's Avatar
jb78L-82
Lots of guys seem to like Blueprint Engines:
  • Picture shown with optional tall, perimeter bolt valve covers.
    This engine requires a 400ci weighted harmonic balancer, and late 350ci weighted flexplate/flywheel.
    BluePrint Engines recommends a 2000-2400 rpm stall converter.
    *A bronze distributor gear is NOT recommended on this engine
    Recommended spark plugs are Champion 792 with .045"" gap
    Not for use in pollution controlled vehicles.
    This engine is not compatible with factory fuel injection.
https://blueprintengines.com/collect...ock-bp38313ct1
Old Dec 8, 2018 | 06:28 PM
C3ForLife1968
nice engine, but I was looking for one that is complete, has a short water pump and without a flexplate
Old Dec 8, 2018 | 07:16 PM
jackson's Avatar
jackson
From GM, not a rebuild not a reman ...All Brand NEW crate 383... about 435 HP ... summit gets nearly $6400
https://www.summitracing.com/parts/nal-19355722
Old Dec 8, 2018 | 08:38 PM
C3ForLife1968
Nice, but it is too expencive for me. I want a COMPLETE engine. It has to include everything. Water pump, alternator, carburator... thanks
Old Dec 9, 2018 | 10:49 AM
cagotzmann's Avatar
cagotzmann
Other item to consider when using any 383, these are usually externally balanced and require a matching flywheel / flexplate for auto or manual transmissions. Also externally balanced engine may still produce a vibration at some RPMS depending on how well the flywheel / flex plate matches the build.
This may be an additional cost if the engine doesn't come with what you need.
Old Dec 9, 2018 | 12:31 PM
derekderek's Avatar
derekderek
Don't be so hung up on the small parts. Alternators can be gotten anywhere. Water pumps are fifty bucks. You insist on without a flexplate. Why? Is your 68 A 4 speed? And you have all the original correct brackets on the previous engine.
Old Dec 9, 2018 | 01:24 PM
C3 Stroker's Avatar
C3 Stroker
......................... I want a COMPLETE engine. It has to include everything. Water pump, alternator, carburator... thanks
Water pump, alternator, carburator...etc, are accessories, not part of the engine. You have to get them separate depending on your specific application.
To Engine swap
