Cutting front springs????
Old Oct 29, 2002 | 05:50 PM
Scooter70's Avatar
Scooter70
Default Cutting front springs????
Has anybody cut their front springs in order to drop the front end? Right now I've got about 27" from the fender lip to the ground and 2.5" from the top of the tire to the lip. This winter I'm going to put in a fiberglass spring in the rear with the longer bolts to drop the rear down and the Bilstein Sports.
So, here's the questions: How much to cut off to get how much of a drop? The springs were new when the car was rebuilt 4 years ago. I don't recall the rating though. The yellow tag on them says "3851100". Anybody know what rating these are? Does this # correlate to the small block w/o air?
The other options is going out and buying the F41 springs. Anyone have any opinions on these? I'd like some sort of ride quality though. The roads in southeast Michigan stink.
Thanks in advance.
Old Oct 29, 2002 | 06:52 PM
72GACRZR's Avatar
72GACRZR
Default Re: Cutting front springs???? (Scooter70)
Why not go all the way and use VBP's front mono conversion? I don't think cut springs are safe. Check with VBP and see if they have a set that are lower. Just my .01 cents.
Old Oct 29, 2002 | 07:13 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Each case will be different depending on spring rate and weight of the car so you will have to take small steps and see what happens. Cut a quarter or a half coil at a time and try it. Use a chop saw or cutoff wheel rather than a torch. Cutting the coils is perfectly safe as long as the temper of the spring isn't destroyed or you cut too much off.
Old Oct 29, 2002 | 07:44 PM
vettedan's Avatar
vettedan
Scooter70-This is a common question on the forum! Cut your springs!!!!Your vette will handle great. :lol: :lol:
Just kidding, The right way is to install big block front springs, It will lower the front by around 3/4" or you can spend the bucks and go with VetteBrakes mono-spring and have a fully adjustable front-end.
Dan
Old Oct 29, 2002 | 08:05 PM
redvetracr's Avatar
redvetracr
scooter,
I am with Burners 100%, cut 1/2 coil it will lower your car and raise the spring rate slightly. As far as "safety' what could a 1/2 coil possibly do with safety? ...redvetracr
Old Oct 29, 2002 | 08:50 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Cutting front springs???? (redvetracr)
scooter,
I cut 3/4 of a coil & lowered my front end to 26.5in. :yesnod:
Old Oct 29, 2002 | 09:02 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Cutting the springs should be no problem. I do it at work routinely.
I cut the springs on my car a few years ago. I was sitting 3/4" too high according to the Z heights in the AIM. With ONE FULL COIL off, I'm sitting at the low end of the spec for the gymkhana suspension (don't have the numbers handy).
Old Oct 29, 2002 | 09:21 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Cutting front springs???? (ddecart)
I've cut a full coil off mine, not a problem. As said, don't use a torch or a cutting disk, the less heat the better.
Old Oct 29, 2002 | 09:45 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i cut just less than a 1/2 coil of mine, dropped the front about 1". i started with a sawsall. looked like a monkey screwing a football! :lol: ended up switching over to the cut off wheel and even ground a bit of a taper into the top of the coil for about 1.5" from the cut. love the look (sig pic is pre-lowered) and the handling is great.
Old Oct 29, 2002 | 10:00 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
Default Re: Cutting front springs???? (clutchdust)
:seeya I dropped a Big Block and it went to the ground. Had to use a couple of spring spacers in each spring just to get it an inch off the ground. :eek: :D :cheers:
[Modified by Intimidator454, 9:02 PM 10/29/2002]
Old Oct 29, 2002 | 10:08 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
looked like a monkey screwing a football! :lol: .
Now THAT is one hell of a visual, thanks for that one !!
Anyway, I cut 1 1/4 coil off of a VB&P 460 lb spring. 1 coil was probably enough though. I used a cut off wheel and it cut like a knife in butter. Handling is much better than with the 550 lb springs that were in there.
See signature pictures.
Old Oct 30, 2002 | 03:53 AM
Frank75's Avatar
Frank75
Default Re: Cutting front springs???? (BSeery)
There's a link somewhere to VIP (Vette Improvement Project) which discusses this and related modifications. I think one coil on SB springs is about 10% i.e. from 300 #/inch to 330. The roads around here are garbage too: my old Trans-Am had 560#/inch springs and it was very harsh.
Old Oct 30, 2002 | 04:17 AM
mapman's Avatar
mapman
Scooter70,
You might see if someone has the NCRS judging manual for your car. For my year (1980), a green tag indicates an original spring and a yellow tag indicates a service replacement spring. The "3851100" number is the GM part number for the spring. The PNs listed in the NCRS manual for 1980-82 are 140XXXXX so I can't help you there.
There may also be a three letter "broadcast code" also on the tag. This code indicates the suspension type. On my 1980 the code was "BHJ", indicating an FE7 option suspension.
Old Oct 30, 2002 | 11:47 AM
GDaina's Avatar
GDaina
Default Re: Cutting front springs???? (vettedan)
Dan
If you ask this question to 10 people, you will get 10 different answers, but the one common denomenator, if you cut your springs, you change your handling characteristics and your suspension dynamics.
Do the job right, do it once, purchase the 427, F-41 equivalent coils. You will be much happier, and the job will be done faster. Just R&R the coils, no grinding, no measuring, not wondering if you cut the same amount off both coils, plus, you keep the suspension geometry as designed by the factory.
Good luck, whatever you decide to do
Old Oct 30, 2002 | 10:57 PM
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
Default Re: Cutting front springs???? (GDaina)
Big Block Springs?
Seems to me that the Big Block springs would have to have a longer free length to havethe same spring rate with the same trim height as a small block car.
In english:
I'd think the BB springs would RAISE the front end because they're designed to hold more load at the same height as the SB springs.
Old Oct 30, 2002 | 11:18 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
If your going to do all the work to take it apart and then guess how much to cut, why not just go with the glass mono spring and have a bunch of adjustabilty with the turn of a wrench :smash: I cut my Vette Brakes touring springs 1/2 coil but the ride was so harsh I ordered the glass spring the next week and never looked back :cheers:
Old Oct 31, 2002 | 01:10 AM
GDaina's Avatar
GDaina
Big Block Springs?
Seems to me that the Big Block springs would have to have a longer free length to havethe same spring rate with the same trim height as a small block car. In english:
On the contrary...if u put sb & f41 bb springs side by side, u will notice the bb spring coils are thicker and overal spring is shorter. installing the bb f41 spring in a sb will lower the the car and give u a stiffer ride
Old Oct 31, 2002 | 09:00 AM
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
Ok, so they're a thicker wire diameter. Gotcha. I'm not a spring design expert...maybe I should call a spring supplier...
Don't big block cars and small block cars sit at the same trim height in the front? I'm assuming that's true. I don't have my AIM handy.
Now, if I have a big block car, the front weighs more than a SB car. More weight, same trim. If I remove weight from the front of the BB car (say by taking off the heads?) so it equals the weight of the SB car, then the front end of the car is going to raise up, right?
To Cutting front springs????
