4 speed to automatic.
Old Oct 29, 2002 | 06:52 PM
philo's Avatar
philo
Default 4 speed to automatic.
Anyone put in a power glide or turbo 350 ? I think that the automatic had a different trans mount and location on the frame. Was their anything else different ? Im looking at drag racing so the information book is open. Thanks, Philo :chevy
Old Oct 29, 2002 | 07:19 PM
LT1driver's Avatar
LT1driver
Default Re: 4 speed to automatic. (philo)
Major difference is radiator has cooling line from trans going to it, frame mount for rear of trams is removable, driveshafts may be different, shifters, flex plate on motor vs flywheel these come to mind. :cheers:
Old Oct 29, 2002 | 07:42 PM
philo's Avatar
philo
Default Re: 4 speed to automatic. (LT1driver)
I know what Your saying , what I wonder about the most is what is special about doing this to a vette itself. I could swear that that the trans mount was different between the two. Till I get to changing it I wont know for sure. Thanks, Philo :chevy
Old Oct 30, 2002 | 12:47 AM
Schmucker's Avatar
Schmucker
Woah woah woah, so you have all the four speed parts? Hmm. I may want those. I don't know if it is more trouble then it is worth right now though... Probably is.
Old Oct 30, 2002 | 07:37 PM
philo's Avatar
philo
Not ready yet to start pulling it . Not till Im sure about the automatic. :chevy
Old Oct 31, 2002 | 10:39 AM
Alwyn678's Avatar
Alwyn678
I might be willing to do a trade if you are interested.......... :cheers:
Old Oct 31, 2002 | 10:54 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Your 4-Speed has a welded in crossmember, where the automatic cars had removable crossmember. I don't know if there is a different location in the placement of the crossmembers, but I doubt it. I imagine you are going to have to cut your crossmember out if you go with an automatic, or pull the engine before you try and install the tranny. I don't think there is room to get the auto up into place with the crossmember in place, but I could be wrong.
I can understand the Powerglide if you are building a serious drag car and are going to be running high-power and a lightened car, but why do you want to use a TH350? The TH350 is a weak sister when compared to a TH400. The TH400 is almost bullet proof and really not much heavier than a TH350.
Old Oct 31, 2002 | 12:35 PM
philo's Avatar
philo
The reason for maybe a 350 is they can be built strong also. granted 400 are stronger but are more for heavy cars and also they need more hps to turn. Its kinda like a 9 inch to a 12 bolt , if you dont need the extra strenth use the 12 bolt , it takes less horsepower to run. Thanks, Philo. :chevy
To 4 speed to automatic.
