Cracked exhaust manifold
Old Dec 21, 2018 | 08:56 AM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
Default Cracked exhaust manifold
Is it repairable
Old Dec 21, 2018 | 09:53 AM
jackson's Avatar
jackson
Per photo, Yes. Find an experienced weld shop; ask if they can weld Cast Iron
Old Dec 21, 2018 | 11:09 AM
carriljc's Avatar
carriljc
Unless it was something special I would just replace it. Actually I'd try welding it myself just for fun first.
Old Dec 21, 2018 | 01:18 PM
ralphspears
Banned Scam/Spammer
It is a 3932461 right side with the holes for AIR tubes
Old Dec 24, 2018 | 01:30 PM
Plasticfreak's Avatar
Plasticfreak
It's tough to weld cast............
Old Dec 24, 2018 | 03:28 PM
domenic tallarita's Avatar
domenic tallarita
I was successful using silicone bronze rod and then peening it as it cooled to stop it from cracking. Also did the V cut and pre heat red.
I would go with the post above and find a good shop that does ALL kind of welding.
Dom
Old Dec 24, 2018 | 03:41 PM
Big2Bird's Avatar
Big2Bird
Yup. Gutter side. Changed a whole fleet of 8 work trucks in the 70's. When they are hot and gutter water splashes up, crack.
Old Dec 25, 2018 | 08:09 AM
Cavu2u's Avatar
Cavu2u
Ralph,
Send it to Dominic.
Steve
Old Dec 25, 2018 | 10:51 AM
fake's Avatar
fake
Take it to a welding shop but get a quote first! These are expensive to replace and most have hair line cracks,but they are out there for full replacement
Old Dec 25, 2018 | 02:16 PM
derekderek's Avatar
derekderek
If it is not leaking exhaust, reinstall it. Welding cast can seal a leak. Won't make it stronger like welding steel.
Old Dec 25, 2018 | 02:51 PM
ralphspears
Banned Scam/Spammer
Now somebody wants to buy it like it is the AIR tube holes are all fine except one has a fitting broken off in it. What is it worth like it is ?
Old Dec 25, 2018 | 03:09 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Nickel rod will do fine without too much hassle. But if it's not leaking I'd just leave it. And if it was I'd probably get another. A welded up original isn't worth anything...so no worse than a nice repro.
JIM
Old Dec 26, 2018 | 03:18 AM
domenic tallarita
Jim,
I like nickle rod. I did ARC welding with that rod on Ford stamping plants cast. We put the cast in a GIANT oven till it was red and then tried not to get heated up. Was easy because of the midwest temp in he winter , or a fan in the summer. But the peening was necessary.
Dom
Old Dec 26, 2018 | 06:35 PM
DUB's Avatar
DUB
I use Muggy Weld and it works.
Can be done with a torch also....because I have repaired cracks in manifolds JUST LIKE what your looks like and it holds.
DUB
To Cracked exhaust manifold
