Head about to Explode!
Old Dec 21, 2018 | 10:38 PM
Little Mouse's Avatar
Little Mouse
Originally Posted by 73VetteRay
So this Howard’s cam cl112571-12, with 215 int. 225 exh. Duration and .455 int / .465 exh lift and 112 Lsa . Rpm range 1,200-5,500. That’s within ballpark of what you’re saying? Or still too much?
even with 64 cc heads and the dished pistons your compression will still not be ideal still a little low. Do a cam 212 int with a tighter lsa. At the low duration number your using you will still have good idle vacuum. The tighter lsa will start pulling a bit lower in rpm and harder in the mid range. Both higher duration the worst contributor and wide lsa lower compression ratios. Something you cant afford to lose.
Old Dec 21, 2018 | 10:43 PM
Little Mouse
You dont need 10 degrees more exhaust duration look for more in the 6 degrees.
Old Dec 21, 2018 | 10:48 PM
Little Mouse
If you had lousy exhaust port factory heads along with factory manifolds and terrible factory exhaust you could use that 10 degrees on the exhaust not good for what your doing you using far better stuff.
Old Dec 21, 2018 | 11:02 PM
Little Mouse
Dont be affaid with a cam at that low duration to use a 108 lsa. The low duration will keep you in the 2000 to 5500 range and the tighter lsa will in crease its overlap a bit. Will make the cam start pulling a bit lower and harder in the mid range. It will narrow the width of the power band a bit.
Old Dec 22, 2018 | 08:54 AM
73VetteRay's Avatar
73VetteRay
Veteran: Marine Corps
Got it. Man this is exactly the type of information that I needed from you guys! Now I have clear view of the direction I need to go. I’m not doing this work right away, like I stated in the beginning, it’ll be done hopefully sometime during first months of the year. I have a path now, so I can start buying the parts a bit at a time. After Christmas. I will get back with a follow up on how the car responds and on what cam was chosen, so that others may follow a similar recipe and not suffer from “exploding head syndrome”.
Thanks to all, and Merry Christmas, Happy Holidays, and Happy New Year!
Old Dec 23, 2018 | 08:34 PM
Little Mouse
When you pull your engine apart assuming the block has never been decked check to see if who ever put 76cc heads on it did not use ..039 or .041 compressed thickness gaskets that are common in most full gasket engine sets. Originally your iron headed engine had ..018 comppressed steal shim gaskets and 76cc chamber heads for as remember 8.25 comp. Even that was a bit optomistic. If the block has never been decked look for a .015 or not much more gasket thats compatibal with an aluminum head you cant use steal shim gaskets with an aluminum head. Anyone that would put 76cc heads back on a dished piston engine sure did not care about any power. Just make sure how far your pistons are down in the hole.
Old Dec 23, 2018 | 10:29 PM
7t9l82's Avatar
7t9l82
Just for grins if the engine is in good shape have you thought about putting a curve in your distributor and advancing the timing? You might be suprised.
Old Dec 25, 2018 | 12:30 PM
73VetteRay's Avatar
73VetteRay
Will do, thanks
Old Dec 25, 2018 | 12:32 PM
73VetteRay's Avatar
73VetteRay
Yes, will look into that
Old Dec 25, 2018 | 01:05 PM
jackson's Avatar
jackson
To OP
With $2K overall budget in mind ...
Those heads you've picked seem a great choice.
But, with wise shopping & (especially) if you were to "settle" for a bit less expensive heads, I can also see a hydraulic roller cam & lifter setup.
Old Dec 26, 2018 | 09:01 PM
73VetteRay's Avatar
73VetteRay
Jackson, you just gave my headache back, just kidding��. I’m thinking those heads for future down the line if and when the bottom end needs to be rebuilt or changed out, then roller cam will come into play, with decent set of heads in the mix. But for now, I’ll stick to my path. Thanks for the input.
