Clutch fork ?
1. Chevrolet has used only two sizes of throwout bearings for decades - 1-7/8" for passenger cars and trucks (flat-finger clutches), and 1-1/4" for Corvettes (bent-finger clutches).
2. The ONLY clutch fork ball stud that's "correct" is GM #3729000, 1-1/2" long. The other one which you will sometimes see, GM #3887159, 1-3/8" long, was released in error for '66, and after hundreds of field failure reports, was cancelled and replaced in production by the good old #3729000 stud on April 4, 1966, which remained in production through the mid-80's. Check and verify that you have the correct length ball stud.
If you have the correct ball stud, be aware that aftermarket pressure plates (or machined/surfaced flywheels) will often require the use of a ball stud that's about 1/8" longer that the stock ball. We install the Lakewood adjustable ball (part number 15501) on almost every clutch job we do to assure proper geometry. If you set the adjustable ball up to produce a ball height 1/8" taller than the stock ball, you will usually be in good shape.
Lars
https://www.corvetteforum.com/forums...vel-range.html
and info added in my revised post above.
Lars
Tom
Tom
https://www.summitracing.com/parts/mcl-75224
And the Mcleod racing Steel flywheel, stock fork and ball stud.
No issues with this.
SB engine, stock bell housing, L88 light flywheel, McLeod 10.5 clutch, Richmond non-OD 5spd trans.I installed the clutch pressure plate, disc, release bearing and fork, and adjustable ball stud and installed the bell housing to the engine. I removed the trans front bearing support and installed it on the tool. Installed and adjustable ball stud on the tool and bolted the tool to the bell housing and hooked up the clutch linkage. I now had a working clutch.The forward motion of the release bearing stops of course when it contacts the fingers of the pressure plate. The rearward motion stops when the bearing hits the base of the trans bearing support. The release bearing supplied with my clutch kit was so long it contacted the pressure plate fingers and the bearing support at the same time. Obviously too long. The stock short bearing seemed to leave allot of lost motion when operating the clutch fork. The intermediate length bearing seem to fit best. Next I set the ball stud length to put the fork at a slightly forward angle at rest and a similar angle rearward with the clutch pedal fully depressed with ~ 1" of top free play. Sounds complicated to read my process but it really wasn't and the clutch works great!
The 4 bolts in the center are to bolt the trans bearing support on. The 4 bolts at the bottom are stored there.They fit through the outer 4 holes to bolt the plate to the bell housing. The other holes is for access to the adjust the adjustable ball stud.
If you want to borrow the tool I'll send to you. May be more than what you need.
Tom
Lars
