Converting point type to magnetic pulse distributor
Old Dec 23, 2018 | 12:48 PM
shark70's Avatar
shark70
Default Converting point type to magnetic pulse distributor
Sometime during the early 1980's, I picked up a magnetic pulse distributor (1111095) , a coil (1115207) , an amplifier (1115005) along with a wiring harness from a swap meet in Englishtown, NJ. This distributor does not have a vacuum advance or a tach drive gear. My research shows it to be an off the shelf item offered by Chevy. Most likely for racing engines.
I would like to use the magnetic pulse distributor in my 70 Vette.
My question, can I take the main body of a point type distributor and add the guts from my magnetic pulse distributor so that I would have the vacuum advance and tach drive capability?
Old Dec 23, 2018 | 12:57 PM
redvetracr's Avatar
redvetracr
I believe the #095 is a ball bearing race distributor so the short answer is no, the long answer is with some added parts and some work you might make it work.
Old Dec 23, 2018 | 02:53 PM
jackson's Avatar
jackson
If you want to keep YOUR tach-drive GM Delco points dist ... suggest convert it to HEI via Lectric Limited Breakerless SE ... only one wire like points.
Old Dec 23, 2018 | 03:11 PM
derekderek's Avatar
derekderek
Easiest is buying a tach drive HEI distributor. Doesn't look original, but...
Old Dec 23, 2018 | 04:08 PM
jackson's Avatar
jackson
That's the cheapest way.
Back when they were about $200 ... I sold dozens of chinese tach-drive HEI ... last time I looked they're much less ... No, I no longer sell them.
Old Dec 23, 2018 | 06:01 PM
Big2Bird's Avatar
Big2Bird
DUI makes a nice HEI unit. Tach drive
Old Dec 23, 2018 | 07:46 PM
shark70's Avatar
shark70
Thanks for all of the suggestions.
I'll research the add on HEI units. I want to keep the original look.
I may just sell the magnetic pulse system.
Old Dec 23, 2018 | 10:00 PM
Big2Bird's Avatar
Big2Bird
Sell it and buy a stock TI unit. About an even swap or less.
Old Dec 23, 2018 | 10:19 PM
riverracer au's Avatar
riverracer au
another vote for "Lectric Limited Breakerless SE", looks stock from the outside, with only the 1 wire connected.
ran it for a couple of years, but i have since gone back to points after Lars rebuilt my dissy.
Old Dec 23, 2018 | 10:27 PM
Big2Bird's Avatar
Big2Bird
And the difference is?.............................Zip,huh?
Old Dec 24, 2018 | 12:02 AM
BLUE1972's Avatar
BLUE1972
True both work well. In my youth I drove all over the universe with points...
Should keep and extra set of either in the "glove" box....
Old Dec 24, 2018 | 08:33 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
2 full summers on the lectric limited breakerless with no problems
Old Dec 24, 2018 | 09:03 AM
3X2's Avatar
3X2
If you keep the TI, make sure you have a GM TI coil. The aftermarket ones seem to be problematic.
Old Dec 24, 2018 | 02:54 PM
squared's Avatar
squared
Default .
You could just convert it back to a points distributor and wire in a Ford TFI module.
Old Dec 24, 2018 | 03:22 PM
Big2Bird's Avatar
Big2Bird
Ford Thick Film Ignition? Those were horrible.
My Lincoln ate them like potato chips.
Old Dec 24, 2018 | 06:47 PM
shark70's Avatar
shark70
The coil I have is the original part number that came with the TI system. The amplifier is the first version.
Old Dec 24, 2018 | 06:55 PM
squared's Avatar
squared
I've had pretty good luck with them on 70s motorcycles, they need to be heat sinked.
To Converting point type to magnetic pulse distributor
Old Dec 26, 2018 | 09:31 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Power wise....you gain nothing. But three things....
1) Mag triggers do not close physically like points so you can leave the key on without issue.
2) My experience is the mag trigger starts faster....not 100% sure why.
3) Mag trigger does not wear out.....no adjustment needed.
Jebby
Old Dec 26, 2018 | 10:05 AM
3X2's Avatar
3X2
A good TI distributor works well into the 9000+ rpm range.
Old Dec 27, 2018 | 02:11 AM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
I think this is what you may want: https://www.davessmallbodyheis.com
