Power steering conversion 75 C3 corvette
Old Dec 23, 2018 | 06:39 PM
christopherj68's Avatar
christopherj68
1st Gear
Default Power steering conversion 75 C3 corvette
wanting to convert my 73 stingray to power steering, I’ve heard there are other model years I could pull from and that I should convert to serpentine as well. My question is what other model years can I pull from and any good YouTube videos to show me how?
Old Dec 24, 2018 | 05:27 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Welcome Christopher, there are numerous threads regarding p/s, if you look to the upper right you'll see search forum.
My opinion would be for you to look a company called 'Borgeson', they sell a kit that will supply you with everything needed for a complete p/s install and it is an upgrade over OEM type p/s. I have their steering system on my 69, it is trouble free and made my car much more enjoyable. T
Old Dec 24, 2018 | 07:12 AM
Gordonm's Avatar
Gordonm
While the stock Corvette PS system works it is ancient in design and there is a lot more under there than is needed. The PS control valve is a known leaker and if you put in a used one I’ll gaurentee it will leak. For the money you will spend finding and putting new hoses and whatever you will be way ahead just buying the kit for a Borgeson steering box for your car. I have had 3 systems, stock, Steeroids and now the Borgeson. The last one is by far the easiest install and works better than the stock system by far.
Old Dec 25, 2018 | 02:19 PM
mrvette's Avatar
mrvette
Borgeson is way to fly today, I did a rack in my '72 about 17 years ago, either one has a much quicker ratio, so 2.7 turns R/L vs the stock 3.7 turns, another thing you want to change is over to a late shark steering wheel......smaller diameter and the thicker rim, so it don't feel like a bus driver wheel in you hand.....
and while you at it, get wider rims and at least 17" diameter.....
then you can get a cross support going between your upper A arms.....
then a plastic spring in the rear......so it don't drive like a tank.....then Bilstein sport shocks all around.....
stick around we help you spend ALL your money.....
Old Dec 25, 2018 | 02:59 PM
naramlee's Avatar
naramlee
damnit you stay away from my wallet!
borgeson is EASY fyi... but you'll probably have to make 2 trips to NAPA to get your power steering hoses custom crimped, the kit hoses are seldom correct
Old Dec 26, 2018 | 12:55 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I hear the Borgeson makes it a true power steering where the stock setup was more of a "steering assist"........
I restroed the system in my 72' because it was in decent shape....but if you start from scratch.....just do the Borgeson.......so much less stuff!
Jebby
Old Dec 26, 2018 | 09:24 PM
jpattt24's Avatar
jpattt24
Just did the borgeson conversion on my non power steering 71. and its the best upgrade I have done beside the 5-speed overdrive. here is some info on it. its a very easy install. steering column shaft was shortened 2 1/4". https://www.corvetteforum.com/forums...n-install.html
Old May 24, 2025 | 11:02 AM
71bbc's Avatar
71bbc
I'd toss a hydro boost into it (since no power brakes) while I'm making hoses and adding a pump. Much better than a bulky vacuum booster. Will make a huge difference in stopping power. These upgrades make these oldies "drivable" actually.
Old May 26, 2025 | 05:07 PM
Way's Avatar
Way
Default Makes my Engine Cringe... Your under hood is Spotless
Just about the cleanest C-3 under-hood I have seen
QUOTE=jpattt24;1598568714]
Just did the borgeson conversion on my non power steering 71. and its the best upgrade I have done beside the 5-speed overdrive. here is some info on it. its a very easy install. steering column shaft was shortened 2 1/4". https://www.corvetteforum.com/forums...n-install.html[/QUOTE]
To Power steering conversion 75 C3 corvette
