Corvette c3 1977 Wipers not working
Old May 22, 2025 | 04:59 PM
Corvette c3 1977's Avatar
Corvette c3 1977
6th Gear
Default Corvette c3 1977 Wipers not working
I think that my wiper switch is broken, is it possible to "bypass" the original switch with another aftermarket one for emergency?
I looked in some wiring diagrams off the 77 but i dont know what relais it is and how to bypass this thing.
My Corvette got a new motor for the wipers and the switch is working just sometimes. Like 1/4 of the time
I'm from germany so spareparts are very uncommon, because of that the bypass idea.
Any Idea?
Old May 22, 2025 | 05:15 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Because '77 is the first year for the steering column wiper switch, the usual recommendation of checking for switch ground isn't applicable. Unfortunately I don't know about this switch (or how to bypass it) but wanted to point out to those coming after me that it's not the same as '68-'76.
Old May 22, 2025 | 05:18 PM
Corvette c3 1977
6th Gear
thanks for the answer,
yeah its the first year and its horrible, this whole construction is overcomplicated.
Old May 22, 2025 | 05:20 PM
Corvette c3 1977
6th Gear
oh i'm sorry, i missunderstood.
but thank you anyway
Old May 22, 2025 | 05:56 PM
bmotojoe's Avatar
bmotojoe
Need more info, can you describe what you think is broken? I'll respond later tonight...
Old May 22, 2025 | 07:07 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Here is a wiring diagram
Old May 23, 2025 | 04:44 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I own a 77 as well. There is absolutely nothing horrible or complicated about the wiper switch or it's wiring.
The wiper switch may have been the first year used on a Corvette, but continued to be used for many years in numerous GM vehicles.
I could post up the schematic however it's already been done.
So, test your wiring. Is it actually the switch? The wiring? Or the wiper motor?
Old May 23, 2025 | 10:44 AM
Corvette c3 1977
6th Gear
Thank you for the answer,
The Motor is brand new and sounds normal when its working,
The switch is working normal for indicating but the wiper didn't do anything if i turn it. I sprayed it with electronic cleaner and it didn't helped.
Now for the diagram, thank you for posting it but i'm not that good with wiring a can't understand it properly.
I wired couple of old bikes before but i don't know anything about relais or something.
How would you handle this situation?
Old May 23, 2025 | 06:35 PM
bmotojoe's Avatar
bmotojoe
I have seen a few problems with these wiper switches, broken pivot bracket, broken washer pump wire at ring terminal, and dirty internal rocker contacts (internal shown in the old post you responded to)...
Few questions:
When you installed the new motor did you transfer the ground lug from old motor to new?
Did you install the ground wire to that lug?
Did you install the 3 connector motor plug correctly? Lt.Blue top, Yellow middle, Black lower.
How did you get the new motor to work, you say it sounds normal when it's working???
Ground lug location white arrow...
Old May 26, 2025 | 10:49 PM
Joey_SS's Avatar
Joey_SS
My late 77 wipers worked intermittently. While replacing the starter, I found some loose ground connections. Cleaned everything with a wire brush, added some dielectric grease and torqued it down. Wipers now work great. Never would of thought my wipers were grounded through the starter.
To Corvette c3 1977 Wipers not working
