From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by TooTall3
Can anyone give me the original spark advance curve numbers at say 1000,1500,2000,2500 and 3000?
A couple things: You failed to mention what engine you're working on, and second, I've never seen any factory information divided into 500 RPM increments.
In short, "no." No specs were published in those increments.
All the specs for the dozen-or-so distributors that were used in whatever car and year you're working on are shown in the "Specifications" section of your Service Manual.
...But why anyone would try to duplicate those specs would be the question. The original specs were established in order to pass federal emissions requirements, and to de-tune the engine enough that warranty claims would be reduced. The specs were further developed for the gasoline blends that were used in the 1970's (assuming you have a 1970's car), which are no longer available or used. Tuning a car to those specs is simply a bad idea, and will result in an exceptionally poorly-running vehicle. You should tune the car (distributor) to specs that are suitable for good performance and to accommodate the fuels that are currently available.
Since you haven't filled out your profile, and have not stated what type of car you have, what year it is, what engine you have, what mods you have, or what type of ignition system you have, it's impossible to provide you with any recommendation at all.
I have an l82 build in an 80 Camaro. Initial set at 12 distributor has 24 so 36 total without vacuum at 3500rpm. I know it should be all in earlier but what I was looking for was is should the curve come in sooner or later ?
Set it up so that the full, total, pegged-out 36 degrees comes in at 2800-3000. That will provide a very nice level of performance with no detrimental effects. Limit your vacuum advance to add no more than 12 degrees. The 3500 spec you have is not bad, but you can gain just a little torque in the mid-range by bringing it in a tad quicker.
Lars
With one weaker spring I am pinging on hard acceleration so back to two silver springs. Idles nice at 14 degrees so I might have to find a way to limit the mech advance a couple of degrees.
When you set up the mechanical advance properly, whatever you end up with at idle is where you want it. You can end up with higher spark advance numbers if your idle speed is set too high, as well.
