I’ve cut several box end wrenches to use for tightening flare nuts.
Remember to look at the angle of the opening of the cut so you remove as little material as necessary from the box end and make the opening just wide enough to slip over the tubing.
You don't need very much torque so I always use 12 point box ends and have cut the open end off several to allow movement in tight places.
Use a narrow wrench, thick wrenches are harder to get into tight places.
Inspect your tubing just behind the flare.
If it has been overtorqued, you can see where the tubing has twisted, or the flare is no longer at a 90 degree angle to the tubing.
Make sure the tubing flare is square to the tubing.
If the angle of the flare is off, even the slightest, the mating surface between the flare and fitting won’t make a good seal.
If the flare is not right, you can cut the tube, using a tubing cutter and re flare the tubing.
Remember to look at the angle of the opening of the cut so you remove a little material as necessary from the box end and make the opening just wide enough to slip over the tubing.
Use a narrow wrench, thick wrenches are harder to get into tight places. I will probably end up doing exactly this to at least one of the wrenches I use for these fittings. The location of the block makes accessibility extremely hard. I also have a remote power steering reservoir and several AN lines mounted above the block to reach around. If I had not just filled the reservoir I could have removed it.
If it has been overtorqued, you can see where the tubing has twisted or the flare is no longer at a 90 degree angle to the tubing.
Make sure the tubing flare is square to the tubing. This is probably one of the problems I am having. The lines do not allow any movement to help align the flare to the seat. It is hard enough just to get my fingertips on the fittings to get the threads started.
If the angle of the flare is off, even the slightest, the mating surface between the flare and fitting won’t make a good seal. This is the reason some have had success by tightening and loosening the fitting until it finally aligns and seats.
Thanks Richard, that's a terrific site for some hard to find tools.
GUSTO
This tool states its for a 37 degree flair. is that what size flair the brake lines have ? and the copper gaskets on that link state 45 degree gaskets ? just wondering ?
Brakes are 45º
AN (Army Navy) type fittings are 37 deg flare also called JIC (joint industrial conference) developed by the SAE for military applications.
I had the same issue with stainless lines on the dist-block, one just wouldn't seal up and weeped just enough to be aggravating. Tried cleaning, tightening, polishing, cursing, etc. Ending up using a copper flare gasket (used on refrigeration lines) it'll form to any imperfection and seals.
I think mine came from summit but amazon etc will have them.
M
I used the copper sealing washers also. It was my combination valve also. Two of those on two new lines. Sealed them right up.
After helping a friend do stainless lines on his 60’s Tbird I vowed to never do stainless lines on my own cars. Nicopp or steel for me. I have used those sealing washers in hvac work with good sucess.
Sounds like the flare and the seat are slightly different angles. Try the copper gasket but I'm with Greengear, every time I've tried to install SS brake lines they always are a bitch to get to seal. Steel should be good for another 40 years.
