Spark plugs - LS3 conversion guys
Old Jan 4, 2019 | 12:49 PM
corvettedave383's Avatar
corvettedave383
Default Spark plugs - LS3 conversion guys
Hey guys, which spark plugs are you using in your LS3/lSX engines, i do like a ngk
Old Jan 4, 2019 | 01:06 PM
ignatz's Avatar
ignatz
Crate motor has AC-Delco 41-985, 0.040 gap. Not sure if they will ever need changing.
Old Jan 4, 2019 | 01:25 PM
corvettedave383
yep thats what my new engine has come with, might need a change for a higher heat range version, for turbos
Old Jan 4, 2019 | 02:25 PM
Gordonm's Avatar
Gordonm
Just running the stock AC Delco LS3 plugs. No turbos but yes turbos might require different plugs. I would go onto LS1 tech and see what the turbo guys are running.
Old Jan 4, 2019 | 04:49 PM
corvettedave383
Ok cheers, will do
To Spark plugs - LS3 conversion guys
