1968 427 headers info
Old Jan 9, 2019 | 04:47 PM
MIKA KLEIN's Avatar
MIKA KLEIN
4th Gear
Default 1968 427 headers info
I'm putting a stock 427 in my 68 any suggestions on type/manufacturers of headers to use?
thanks
Old Jan 9, 2019 | 07:11 PM
ronarndt's Avatar
ronarndt
MIKA- I have a NOM 454 in my 68 convert and the PO used Heddman long tube headers. They fit- sort of. It was necessary to put a dent in the tubing on both the driver side and passenger side to clear the steering gear and the mounting bolt for the pitman arm. I looked at the available "block hugger" headers and they appear to clear the side of the engine compartment better. Hope you get some suggestions, since I am also looking for something that fits.
Old Jan 9, 2019 | 07:38 PM
forman's Avatar
forman
was the car a 427 car before ,, if not you might want to change the front springs to the heavy duty
Old Jan 10, 2019 | 12:42 AM
MIKA KLEIN's Avatar
MIKA KLEIN
4th Gear
Default 427 car?
I got this car from my uncle that died, so I don't know much about it. It has a 72' 350 in it now. I was told to measure the radiator and sway bar and look for a notch out of the front frame cross section is this correct? it all points to 427 thanks for the tip I'll probably put new springs in anyway
Old Jan 10, 2019 | 01:00 AM
ddawson's Avatar
ddawson
I have the Hedman headers on my 427. I had to dimple the passenger side.
Old Jan 10, 2019 | 02:33 AM
OldCarBum's Avatar
OldCarBum
I have a set of new Sanderson short tube headers for sale in the parts for sale section.
shoot me a pm if you are interested.
They were only removed from the box for photos and they are beautiful.
Greg
Old Jan 10, 2019 | 11:06 AM
frankiebrown's Avatar
frankiebrown
Mc Jacks makes good headers
Old Jan 10, 2019 | 02:12 PM
3X2's Avatar
3X2
Under car or side exits? ACP/Stahl for side exits.
Old Jan 10, 2019 | 03:25 PM
MIKA KLEIN's Avatar
MIKA KLEIN
4th Gear
Default It has side pipes
it has side pipes off headers from a 72' 350
Old Jan 10, 2019 | 09:39 PM
ZAKsPop's Avatar
ZAKsPop
I have Heddman on my 69 BB.
To 1968 427 headers info
