Engine ID
Old Oct 30, 2002 | 05:27 PM
67SS's Avatar
67SS
4th Gear
Default Engine ID
Hi Guys!
I am still trying to ID engine in my 75 Vette. The previous owner could not offer much help. He said it was a chevy 350,4bolt main, not orginal engine. I checked the pad on the passenger side cyl head. I only could make out the last two digits(00). On the rear of the engine,driver side, I found a casting clock,just to the left, the number 14816379 with GM above the first three numbers. Any help would be appreceiated. Thanks Again, Rich :confused:
Old Oct 30, 2002 | 05:41 PM
sb69coupe's Avatar
sb69coupe
Default Re: Engine ID (67SS)
I can't find a list for the casting number you provided. Possibly he read the 3rd digit as an 8 when it's really a zero? If so, then you have a 350 block from a 77-79 Chevy, could be either 2 or 4 bolt.
14016379...350...77-79...2 or 4
Old Oct 30, 2002 | 10:53 PM
stpman's Avatar
stpman
if the 3rd digit reads 3 instead of 8 the MSA-1 book calls it up as a 86-88
car/truck 350 with a one piece rear seal.
To Engine ID
