Top end upgrade vs crate engine
Old Jan 15, 2019 | 09:46 PM
wonl2's Avatar
wonl2
Default Top end upgrade vs crate engine
Greetings, I have a survivor L48 79 with just over 60,000 miles. I want to get more horsepower for my ride. I was looking at crate engines but I'm worried about receiving an inferior engine. I was also looking at upgrading the top end with new heads, intake and cam. My goal is a 350+ hp engine. Any thoughts and/or opinions on which direction to go? Any comments greatly appreciated. Thanks
Phil
Old Jan 15, 2019 | 09:51 PM
gjohnson's Avatar
gjohnson
Retire the L48. Check out Blue Print Engines. Getting ready to order mine # BP3503CT1
Old Jan 15, 2019 | 10:00 PM
titanle's Avatar
titanle
I ended up having the top end rebuilt on the 350 that's in my 68. Its not the factory correct motor, when it was taken apart it appeared to be an early 70s truck motor. So we built on that, new aluminum heads, cam, intake, carb and torque stall converter. Our goal was to achieve 400-425hp at the crank.
Old Jan 15, 2019 | 10:21 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
At only 60k miles that block should be in reasonable shape. I'd jerk the engine, take it apart and decide then. I don't know if the L48 were dished or flat, my 79 had a replacement engine when I got it. There may not even be much cylinder wear, might get by with a quick hone to tidy up. Since you are looking for modest hp, if the pistons are flat topped & the bores are good, and none of the bearings show signs of damage then: hone the cylinders, install new bearings & seals, new oil pump, choose cam, heads, intake, carb, ignition to achieve your goal and put it back together. This gives you lots of experience in how things go together and work. If this is intimidating, that's okay - go the replacement engine route. If you go with a reputable source then the chances of getting a bad engine are low. Because of economy of scale, you might get an engine package cheaper than doing it yourself.
Old Jan 15, 2019 | 10:52 PM
jackson's Avatar
jackson
Phil
what is your budget?
OE L48 has dished pistons
Old Jan 16, 2019 | 02:55 AM
cv67's Avatar
cv67
St. Jude Donor '05
ID be tempted to toss in a BP 400...maybe even sneak a B and M blower on it. Talk about endless tq..
Old Jan 16, 2019 | 08:07 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Original SBC from the 60s and the 70s have a usefull life span of about 90k to 100k depending on maintenance. Yes there are some that get a lot more mileage out of them So your engine is approximately 2/3 worn out. By replacing cam and heads you will increase your compression causing some compression to push past your rings causing blow-by. Note to all who want to argue: this doesn't happen to all engines. Just wanted to advise OP that this could happen. Remember that this engine is in a Corvette and previous owners might of driven it like a Corvette should be driven and that does take a toll on engine longevity. T
Old Jan 16, 2019 | 08:14 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
This is a good point.....unless that engine is pristine, it could cause piston blow by. Stock L-48 had crap cast iron rings that are eggshell brittle........
I have done it though......put a whole top end on a pathetic 350 truck engine (That had .050 in the hole stock pistons in it) and ran Dart 180's, Comp 292h Magnum, and a tunnel ram (yes, tunnel ram) with two Holley 450's through a 350 turbo with 3000 stall in a 3300lb. 37' Ford Business coupe.....damn thing would make you giggle......but I even told the owner that about ten hard 1/4 mile passes and this engine is done.
Jebby
Old Jan 16, 2019 | 12:31 PM
DAD111's Avatar
DAD111
You will never get 350+ HP out of that motor unless you redo the bottom end too. Maybe 2 turbo chargers or nitrous shot with the top end work you will get close.
Old Jan 16, 2019 | 12:43 PM
jb78L-82's Avatar
jb78L-82
9:1 pistons, decent flat tappet cam/moderate roller cam, aftermarket 64 CC iron heads (10:1 compression)...easy <400 gross HP with a cast crank L-48 rods......Heck a bone stock non emissions stock L-82 made 310 Gross HP back in the 70's......
Old Jan 16, 2019 | 01:04 PM
jackson's Avatar
jackson
https://www.ebay.com/itm/GM-OEM-NEW-...nA85:rk:6:pf:0
Summit-Jegs get over $2K for same motor
Again, I checked to update price on above crate last night ...and did a "what if" at checkout...advertised price $1746...checkout showed $100 discount....so $1646...then the dealer gives $50 spend anywhere giftcard ...so delivered price is $1596. For a Brand New L31 Vortec head roller cam 4 bolt main 350ci motor. $1596 NEW
Take that … pay a local machine shop $100 to finish the fuel pump mount pad... spend another $500 on valve springs & bigger cam...For under $2500 you'll have an all new motor easily making 350-400 hp at crank.
BTW, BluePrint 350, 383, 396 motors have used blocks that're already bored +0.040" over … look it up it's on BP website.
Old Jan 16, 2019 | 01:34 PM
DAD111's Avatar
DAD111
I disagree on that 310 hp. In 79 that motor L-48 only produced 190 HP. with all the smog crap and small valves 8:5 to 1 compression.. With it being a stock bore and crank with dished pistons he could get 300 +, But not 400 gross HP.
Old Jan 16, 2019 | 02:00 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Heads, cam, intake and carb.....it would make 400 very easily, even with crap dished pistons.....just use a 64cc head for 9.2 to 1.
The 79' L-48 is a bad engine to compare as the cam barely lifted the valves off the seats.
The 350/200 that came in my Vette would make an easy 275 hp with a pair of headers on the dyno at 8.5 to 1 compression......this is on par with the GM Goodwrench crate engine with a Q-jet setup......
The only thing in an L-48 that stinks is the no-quench pistons....but if the timing curve is right....no issues there either.......you may lose 15 horsepower with crappy quench...or about 2 horsepower per cylinder.
A Goodwrench crate engine with Dart 180 heads, Air Gap, and a Comp 280H Magnum cam would make 400 horsepower no problem......all day.
Jebby
Old Jan 16, 2019 | 02:14 PM
jb78L-82's Avatar
jb78L-82
What I said was that a non-emissions L-82 made 310 Gross HP...Here is the source if you doubt it:
Super chevy magazine as well:
"Loyal readers will remember that the low-compression L82 was equipped with 882 heads, L46 hydraulic cam (0.450/0.460 lift, 222 duration) and an induction system consisting of a cast-iron intake and Q-Jet carb. The Q-Jet was actually less of a hindrance than you might suspect as the 750 cfm rating was more than adequate for the needs of the 250hp L82. In stock trim on our dyno, the 9.0:1 L82 produced 313 flywheel (gross) horsepower at 5,500 rpm and 355 lb-ft of torque at 3,800 rpm. The engine produced adequate torque relative to the horsepower rating, but it wasn't exactly what you'd describe as earth-shattering."
All horsepower discussed is GROSS NOT Net (much more real word), including carte motors which are almost all, GROSS HP, NOT Net. There is a big difference in the outputs..despite most who want to deny this variation as not significant.
Old Jan 16, 2019 | 02:33 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
A 100K on a 70's sbc? If pampered, maybe. I got 65K out of my L-82 which has all the good internals. Anyway, I would put that L-48 in a bag if it's number's matching. Otherwise, toss and get a crate.
Old Jan 16, 2019 | 02:37 PM
F22's Avatar
F22
Voodoo Hydraulic Flat Tappet Cam - Chevrolet Small Block 262/268
Product Description
Lunati's Voodoo series of Hydraulic camshafts deliver more area under the curve than any other series of Hydraulic camshafts. This means more throttle response, quicker acceleration, more vacuum, better efficiency, combined with maximum horsepower and torque! Hydraulic Flat Tappet. Mid-level performance street cam with excellent drivability. Exceptional replacement for muscle car type cams with automatic transmissions. Works well with stock type exhaust manifolds and dual plane intake with mild 4 bbl carb. This is an Awesome 4X4 and performance marine cam.
  • Advertised Duration (Int/Exh): 262/268
  • Duration @ .050 (Int/Exh): 219/227
  • Gross Valve Lift (Int/Exh): .468/.489
  • LSA/ICL: 112/108
  • Valve Lash (Int/Exh): Hyd/Hyd
  • RPM Range: 1400-5800
  • Includes: Cam Only
Part Number: 10120702
Old Jan 16, 2019 | 02:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
GM Hotcam kit is less than $500 I bet and will wake things up. Add a set of nice 180cc heads should be a good reliable runner wiht manners. May even crack a 13
To Top end upgrade vs crate engine
Old Jan 16, 2019 | 02:46 PM
F22's Avatar
F22
The L98 heads, because they have small 58cc combustion chambers, work really well with a stock, dished piston L48. Add the cam, an Edelbrock Performer (regular, not the RPM), headers and a Holley 650 Carb and you will be good to go, without touching the bottom end. Don't forget new lifters, if you get a new cam. My L48 motor, really woke up, with this combo. It was plenty fast, pulled hard all the way through the 1/4 mile at the drag strip (low 14's) and had 175-180 pounds of compression on the cylinders. I picked an RV-Marine-4x4 cam, because for a mild build, torque is more important than absolute horsepower, especially at the bottom end of the RPM range, where you want it to kick you in the butt when it takes off.
Old Jan 16, 2019 | 02:57 PM
DAD111's Avatar
DAD111
This is what im getting at is – People get disappointed when they dyno their car and it dynos at 320 HP when people are telling them that you should be 400+ HP with that motor because it’s what he said. Gross vs RWHP is a lot different. I’ll leave it at that
If you want it to run better and cannot pull the motor – Then do as they are telling you . 60,000 miles aint bad – people do it all the time with no issues. Gotta remember it’s a small block Chevy, one of the best proven motors of all time. That thing would run on paint fumes if it had too.
Old Jan 17, 2019 | 02:11 AM
cv67's Avatar
cv67
St. Jude Donor '05
x2 350hp perhaps but 400 wont be made with low compression, a 200-215cfm cfm head , baby cam and headers no way
