1975 factory alarm question?
Old Jan 16, 2019 | 09:38 AM
DAD111's Avatar
DAD111
Default 1975 factory alarm question?
When the alarm goes off - Does it sound the horn and flash the lights or just sound the horn? 1975 factory alarm
Thanks Mike
Old Jan 16, 2019 | 10:19 AM
Maymyvetteliveforevr's Avatar
It only sounds the horn, which is located drivers side rear beside the antenna.
Old Jan 16, 2019 | 10:21 AM
DAD111's Avatar
DAD111
Thanks for the reply
Old Jan 17, 2019 | 11:19 AM
DAD111's Avatar
DAD111
I know this subject has been beaten on for a long time, But I have a few questions. Here is what I have
1. The system works
2. The anti-theft tamper switch is broken – threaded part missing. Unplugged broken switch and put a jumper wire to prongs on plug
3. Hood is off car. Unplugged terminals at hood switch
4. Close both doors and Door ajar light goes off. When doors are open light works.
5. Key out of ignition
6. Turn key at fender to set alarm – As soon as I turn the key the horn starts to blow. This is where im having the issue, Not sure where to go from here.
Thanks Mike
Old Jan 17, 2019 | 08:07 PM
gjohnson's Avatar
gjohnson
. My 76 had factory alarm that gave me problems.I got rid of it.
Old Jan 17, 2019 | 08:41 PM
BLUE1972's Avatar
BLUE1972
Un jump the switch under the hood.
The system is a positive feed system . Any switch that makes contact with ground will trip the alarm.
Old Jan 17, 2019 | 08:55 PM
BLUE1972's Avatar
BLUE1972
It's an easy system, the flasher just opens and closes the circuit..
To 1975 factory alarm question?
