Temps and stat
I can't see why people find this so difficult to understand. I've posted many times on this and supplied references from various sources such as the GM service manual, guys with Ph.D's who study this **** for a living in which car companies use that information to design their cooling systems to prevent engines from over heating.
If a car is overheating, example: 180* ts and guage is reading 210*, then there is a defect somewhere in the cooling system. Most likely, a clogged radiator which is a reduced cooling capacity condition. Or, if the engine is modified from 200 hp to 500 hp and the coolant capacity didn't change, then a good chance there will be overheating.
If your Vette runs 230 degrees with a 195 thermostat
it will run 230 degrees with a 180 or 160 thermostat as well.....it just will.
If your Vette runs a steady 180 with a 180 stat....you Might run cooler with a 160....if the cooling system is that efficient enough.
Jebby
Nothing wrong with 160*. Its not too cool. Ask the drag racers as they bring their car into staging with a cold engine.
Lars
Now my question and we have a lot of smart people here is, and this always makes me think then the smoke out my ears happens LOL.
Giving that the cooling system is working properly why is it that during hotter times of the year engines supposedly run hotter.
Now here’s where I get confused if the ambient temp is way lower than the engine temp, let’s say it is 95 degrees out and your car gets hotter than when it is cool. I mean I hear people say all the time my car runs hotter in the summer.
Why is that guess my mind does not wrap around 95 degrees making 195 degrees hotter it’s 100 degrees cooler so it should get a fair amount of heat exchange. Did any of that make sense or did I just make myself out to be a dummy ��
Sorry to hijack your thread.
