1969 350 base timing chain
Old Jan 22, 2019 | 01:34 PM
1969Turbo-Fire's Avatar
1969Turbo-Fire
Default 1969 350 base timing chain
I know this is old question but what timing set will you guys recommend in stock 300/350 -69 engine?
Good quality, reasonable price which would go bolt on in stock engine.
There is like 100 different options...
Old Jan 22, 2019 | 01:38 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Cloyes 9-1100 Street True Roller.....about $40 at your local part haus.......best timing chain you can get for the money and all you need......
While you are down there though.....replace the balancer with a unit that has timing marks on it....change the front seal, and install a nice timing pointer. You will thank yourself later.
Jebby
Old Jan 22, 2019 | 01:41 PM
1969Turbo-Fire
Thanks, balancer and seal is replaced 2 years ago.Of course i replace seal maybe this time too.
Old Jan 22, 2019 | 02:27 PM
HeadsU.P.'s Avatar
HeadsU.P.
I believe Cloyes makes three units, three price ranges. Like Jebby said, the True Roller is tops. You have too much at risk to ever go with a $19.95 unit. Pistons meeting valves is the kiss of death.
Try Summit for prices, pictures, & reviews.
Old Jan 23, 2019 | 04:25 AM
7T1vette's Avatar
7T1vette
Never 'pinch pennies' when replacing IMPORTANT hardware. And the timing chain/gear set is IMPORTANT!!!
Old Jan 23, 2019 | 10:01 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Base 69 300hp 350 have a plastic gears impregnated onto a metal casting. When I discovered that my 69 needed a new timing gear set I found more that 25 % of the plastic missing. My engine had 85,000 miles on it. Some of the pieces were sucked up into the oil pump pick up tube assembly, T
Old Jan 23, 2019 | 10:09 AM
Big2Bird's Avatar
Big2Bird
Old Jan 23, 2019 | 10:34 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
BTW.....I have one on the shelf I didn't use for $25 plus shipping if you want it!!!! Brand New in the box!!! Or trade me something for it!!!
Jebby
Old Jan 23, 2019 | 12:41 PM
jackson's Avatar
jackson
Jebby
That's a nice offer from Jebby and it'll do a great job
Base, stock 350... won't go wrong with what came in it as well (EXCEPT No Plastic)… Cloyes pn C-3001K … has the strong, quiet Morse aka Link-Belt chain but no plastic on gear
https://www.summitracing.com/parts/c...001k/overview/
you can spend $10 - $500 on a timing chain set. For those that might dismiss a Morse chain look here ….Melling pn 40520
https://www.summitracing.com/parts/mel-40520
Old Jan 23, 2019 | 03:59 PM
cv67's Avatar
cv67
St. Jude Donor '05
Cant beat Jebbys offer. For a stock engine a basic stock type chain is fine, just get rid of the plastic gears. They last a long time
Old Jan 23, 2019 | 04:08 PM
Big2Bird's Avatar
Big2Bird
Can we say sprockets? Gears are for counter rotation boat motors. Just sayin......
Old Jan 23, 2019 | 05:08 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Basic $30 Cloyes with 3 positions to adjust cam timing works fine. Heck I used them in my 540 with springs you could hold up a house with, solid roller cam with .774" lift and 8000+ RPM. Never an issue.
JIM
Old Jan 23, 2019 | 05:33 PM
jim2527's Avatar
jim2527
I used to double roller CloyesJebby recommended from Summit.
if was a nice a tight fit. Had to heat the chain up to get it together. Otherwise bolted right up with no issues.
Old Jan 23, 2019 | 05:35 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
E-Mail me if you want me to send the set.
Jebbysan@hotmail.com
Jebby
To 1969 350 base timing chain
