454 High-Compression Engine setup
Old Jan 26, 2019 | 04:06 PM
swissblock's Avatar
swissblock
5th Gear
Default 454 High-Compression Engine setup
hello guys, I'm new here in the forum
I'm from Switzerland and last year I bought a big block of 73. A great car.
Now I want to increase the performance. The engine was completely overhauled 5 years ago, all original.
Now I want to change the cylinder heads and the camshaft in the first step.
I have seen the Edelbrock Performer High-Compression 454-O heads, I already have a Victor Junior Intake. Can you recommend the setup and what kind of camshaft should I use?Thank you for your answers and sorry for my bad English.
greetings from Switzerland
Old Jan 26, 2019 | 04:09 PM
redvetracr's Avatar
redvetracr
anywhere near Lake Thun ? I`m looking for an ex Corvette guy from there named Hans Hirt...
Old Jan 26, 2019 | 04:13 PM
swissblock's Avatar
swissblock
5th Gear
Unfortunately I do not know him. But my uncle used to be in the Corvette Club Switzerland years ago, I'll ask him.
Old Jan 26, 2019 | 05:42 PM
zwede's Avatar
zwede
I have a '71 LS5 454. Basically the same engine.
The Edelbrock 100cc heads will give you about 1 ratio higher compression. Not enough to make it 'high compression', about 9.5:1 maybe. But that's if the deck is near zero which it won't be if it's factory. Mine was crooked from the factory so cylinders had everything between 7.5 and 8.2 compression.
I finally took the plunge and yanked the engine and had it decked. They saved the numbers (although the machinist had some choice words afterwards. it was not easy). I went with forged pistons with a small dome. With the Edelbrock heads I now have a true 10.15:1. For a cam I recommend this: https://www.summitracing.com/parts/l...0712/overview/
This is a hydraulic roller cam which means you'd also need some other things to make it work. Roller lifters as well as compatible valve springs and a timing cover with a cam bearing. Not cheap, but I'd only recommend hydraulic roller cams for street use these days as the risk of running a cam flat is too great. No fun chasing special zink-oil or messing with additives hoping they'll protect the flat tappet cam.
Old Jan 26, 2019 | 07:03 PM
ddawson's Avatar
ddawson
I'm using the Edelbrock heads with this cam.
http://www.claysmithcams.com/bbc-454...x-of-6000-rpm/
Agreed on changing the valve springs.
Old Jan 30, 2019 | 02:32 AM
swissblock's Avatar
swissblock
5th Gear
Thanks for the great answers.
I think I will order the camshaft from Summit because the shipping to Switzerland works great here.
once everything is installed I give a feedback if it works
Old Feb 1, 2019 | 02:40 PM
Grumpy 427's Avatar
Grumpy 427
I am thinking you should get rid of that intake for an RPM performer if your going with oval port heads and a hydraulic cam, this motor will be done by 5500-5800 rpm anyway. pick a cam in the .550-.585 lift and .245/.255 duration at .050
Old Feb 2, 2019 | 09:52 AM
derekderek's Avatar
derekderek
Victor Jr is a great full-throttle intake. Drag car or high perf boat. You lose quite a bit of power from idle to 5k rpm, which is where it will spend all it's time. Check with edelbrock. Not sure which manifold, but they make a dual plane with ports that match those half-oval, half-rectangle heads.
Old Feb 2, 2019 | 06:34 PM
OldCarBum's Avatar
OldCarBum
I went with the Edelbrock Performer RPM Air Gap.
Edelbrock recommended it for my 496, with the Edelbrock Performer RPM heads with oval ports.
They said it’s an almost perfect port match and will work best from idle through 6000 rpm’s.
I went with a Crane, HR 230/236, 590/610 with an operating range of 2000-5800 rpm’s which Crane told me will realistically pull through 6000 rpm.
I’ll be at 10.4 to 1 CR and a Quick Fuel Q-850 carb.
Old Feb 2, 2019 | 06:53 PM
Grumpy 427's Avatar
Grumpy 427
A dual plane is the way to go with something like this.
Old Feb 2, 2019 | 06:54 PM
Grumpy 427's Avatar
Grumpy 427
Nice combo, did you dyno this motor?
Old Feb 2, 2019 | 07:41 PM
OldCarBum's Avatar
OldCarBum
Everything is sitting on the self waiting for the body off resto/mod starting later this year.
It will go on the dyno for break in and tune once it’s assembled.
Old Feb 2, 2019 | 07:53 PM
Grumpy 427's Avatar
Grumpy 427
Cool cant wait. post the sheet when you get it done please.
Old Feb 4, 2019 | 11:43 AM
OldCarBum's Avatar
OldCarBum
Will due!
To 454 High-Compression Engine setup
