Temp Gauge issue
Old Jan 28, 2019 | 01:20 PM
Dwight Allan's Avatar
Dwight Allan
3rd Gear
Default Temp Gauge issue
I have a 1973 corvette convertible manual shift 350 cu in. I have an after market manual temp gauge that I want to remove. I have the new orginal gague that is electric. I cant find the factory wire for the gauge. There is one poll on the new sending unit. My wiring for the gauge is a three wire. Blue, light blue and black. I need a wiring diagram or advice on which wire is the sending unit?
Old Jan 28, 2019 | 02:35 PM
MelWff's Avatar
MelWff
where is the current sender located, the drivers cylinder head towards the front?
Old Jan 28, 2019 | 02:42 PM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
https://docs.google.com/viewer?a=v&p...ZTM0ZDc1MWM5Ng
Old Jan 30, 2019 | 10:35 AM
Dwight Allan
3rd Gear
Yes thanks for your hel!
Old Jan 30, 2019 | 10:36 AM
Dwight Allan
3rd Gear
Help
Old Jan 30, 2019 | 12:22 PM
7T1vette's Avatar
7T1vette
"If you need hep, here I am."
Old Jan 30, 2019 | 04:17 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Very nice pic and would be awesome if the wires had all the colors marked on there as well in case BUBBA got in there and changed some things. Thanks for posting, but I think there is a mistake.
Shouldn't it go like this (below) for the fuel gauge? According to the diagram, there are only two wires, TAN and Black. Blank is ground, not 12 volts and Tan looks like 12 volts. I didn't check the others for accuracy.
Old Jan 30, 2019 | 05:54 PM
Peterbuilt's Avatar
Peterbuilt
Default Read this!
Old Jan 30, 2019 | 09:07 PM
Buccaneer's Avatar
Buccaneer
That may be that diagram, but the diagram you linked in the other post #3 shows it differently, jus sayin'.
Old Jan 30, 2019 | 09:35 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi again.
Let's look at the '73 schematic again.
On page two, at the gauge, I see a PINK and a TAN.
Pink at the gauge goes to a fuse and gets powered-up with the key in ON.
The TAN goes into the bulkhead connector and out to the fuel sender and the fuel sender has a separate black ground.
Old Jan 30, 2019 | 10:00 PM
Buccaneer's Avatar
Buccaneer
Maybe I'm looking at something else then... EDIT, I was looking at the wrong thing... Dah!
To Temp Gauge issue
