Fuel injectors
Old Feb 1, 2019 | 09:25 PM
jose7740's Avatar
jose7740
Default Fuel injectors
I was checking the injectors on the 82 crossfire, the front number was 5233776 and the rear was 5233770, I believe the rear is the correct number, not sure about the front one. What are the correct numbers for the 1982?
Old Feb 1, 2019 | 10:27 PM
Gunfighter13's Avatar
Gunfighter13
The stock front and rear have different part numbers. https://www.rockauto.com/en/catalog/...+injector,6224
Old Feb 2, 2019 | 12:44 AM
jose7740's Avatar
jose7740
Thanks for the reply, I saw
Old Feb 2, 2019 | 12:57 AM
jose7740's Avatar
jose7740
I goofed the previous post, thank’s for the reply. I saw a previous post where a member listed the original GM injector numbers front and rear for the 82 crossfire system but I can not find that post, does anybody have those numbers and be able to show them? Thanks in advance.
Old Feb 2, 2019 | 01:26 PM
jose7740's Avatar
jose7740
I cleaned the front lnjector well and rechecked the numbers, the front one has the correct number, it ended in 5 not 6 so everything is good.
Old Feb 2, 2019 | 03:04 PM
Gunfighter13
I have TJ11 injectors front and back. They are #90, but I have a setup like Buccaneer.
Old Feb 2, 2019 | 09:55 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Run good?
Old Feb 2, 2019 | 10:58 PM
jose7740's Avatar
jose7740
My 82 was sold by a dealer, they said the engine was worked some, it has aluminum heads, headers and maybe a transmission shift kit, the previous owner left the stock injectors, I am going to try to find out what was done to see if it needs a bigger fuel pump and bigger injectors, I drove it today and it moves very quickly.
To Fuel injectors
