LSx Swap Water Pump Heater Fittings
Good afternoon all,
I did a fair amount of research on the forum and others on water pump fittings and I eventually settled on these: http://www.hydraulichoses.com/Produc...oductCode=4503 , 4503-10-06 and 4503-12-8. I confirmed they fit in the car, they clear the upper control arm with about 3/8" to spare. I have my motor as far forward as possible, if the engine is farther back it may not work depending on the position. In the picture below they are not threaded in all of the way, in their final position they will be about one thread away from bottomed out.
Scott
Scott
The following 2 users liked this post by ScottEwine:
corvettedave383 (02-04-2019),
supervette64 (02-06-2019)
Did the same thing! Have my engine about as far back as it can go. Pretttty close but it does clear.
At some point I want to lower my engine more in which case I'll have to find a different solution.
ScottEwine (02-06-2019)
ScottEwine (02-08-2019)
Scott
Received 1,128 Likes
There are 45 degree adapters that will give you a little more clearance.
Secondarily, you're best off, I think, to change out the upper A-arms to an adjustable set (no shims).
And third, I modified my thermostat housing to angle down and give me clearance for my spreader bar. I posted elsewhere with a picture of that.
