Vibrations from shifter
Old Feb 9, 2019 | 10:02 AM
Bhebert449's Avatar
Bhebert449
Default Vibrations from shifter
I have a 69 427 with the 4 speed manual M21 transmission. When I hit speeds above 70mph I get a lot of vibrations from the shifter. I’ve read several posts that list different causes including linkage, drive shaft, etc. I’ve had the drive shaft balanced and that didn’t resolve it. Anyone else have this issue and have any recommendations?
Old Feb 9, 2019 | 11:15 AM
Billenglish's Avatar
Billenglish
As long as you are certain it's not the drive shaft (I had a shop swear they balanced mine, they didn't, took it elsewhere and it resolved the issue), it's got to be elsewhere in the drive train. Most likely the harmonic balancer. Did this start recently, what did you change, if anything?
Old Feb 9, 2019 | 11:18 AM
Big2Bird's Avatar
Big2Bird
How old/what kind of clutch?
Old Feb 9, 2019 | 11:30 AM
Bhebert449's Avatar
Bhebert449
Not sure about clutch. I was told it could be the bearing where the yoke attaches to the transmission?
Old Feb 9, 2019 | 11:34 AM
Borrowedtime's Avatar
Borrowedtime
Have you gotten under the car and attempted to give the drive shaft a good shake? Typically, if the shifter starts vibrating, I suspect u joints first. Especially if the vibration is speed dependent and not RPM dependent. Chock the wheels, put the car in neutral, grab the drive shaft and check for movement. Also check for any evidence for witness marks where weights that should be attached to the drive shaft are no longer there.
That's the easy stuff. After that,
Old Feb 10, 2019 | 08:16 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
check motor mounts and transmissoin mounts for cracks and loose bolts
Old Feb 10, 2019 | 03:29 PM
pauldana's Avatar
pauldana
Bolded,,, what he is getting at is,,,, is it a Centerforce clutch?
if so... may be your problem... thoes weights NEVER self center.. and do cause vibration.
Also, if you do not have proper drive shaft angle, a "Z" angle it will vibrate as well.. do you have stock suspension? ie, ride hight?
are all transmission mounts good, and tight? the rear end snubber, is it also in good condition, and tight?
Old Feb 10, 2019 | 04:42 PM
Oldriceguy's Avatar
Oldriceguy
My vibration turned out to be a half shaft u-joint. The joint was tight, had no play in it. But, when the half shaft was taken off the car, a tight spot could be felt when the moving the u-joint. Turned out to be wear between the bearing and the cross member. New u-joint repair kit fixed the vibration.
Old Feb 10, 2019 | 05:20 PM
JoeMinnesota's Avatar
JoeMinnesota
I had this issue in the past with a ‘67 Camaro also a Muncie. The car was run at the strip a few times and vibration as you describe. Ended up being a sprin/tweaked input yoke on the rearend. The problem could be virtually anywhere in the drivetrain. Replaced the front yoke and problem solved.
To Vibrations from shifter
