Fuel leaking from carb
Old 02-09-2019, 01:12 PM
Bhebert449
Bhebert449's Avatar
Default Fuel leaking from carb
I have a 69 with a 427 tri power carb setup. Today I noticed fuel leaking from the center carb. It appears to be coming from where the carb attaches to the manifold. See attached pics. Thoughts? New gasket needed? Is this a relatively simple repair?
Old 02-09-2019, 01:15 PM
TimAT
TimAT's Avatar
I would suggest the accelerator pump diaphragm...but I'm not there looking at it drip.
Old 02-09-2019, 01:17 PM
Jebbysan
Dr. Detroit
Support Corvetteforum!
Jebbysan's Avatar
Received 3,892 Likes on 2,564 Posts
Pull the carb and go through ALL of the gaskets. Chances are, that if the accelerator pump is leaking....the other gaskets are right behind it.
Jebby
Old 02-09-2019, 01:43 PM
Bhebert449
Bhebert449's Avatar
Jebby
Thanks. When I pushed on the throttle fuel squirts out from under the carb. Is removal pretty straightforward?
Old 02-09-2019, 01:50 PM
3X2
3X2's Avatar
It's been a while, but I think you need to remove one of the end carbs to get the center one off. At that point, I would regasket all three. Do not over tighten the mounting bolts/nuts. Something like 60 INCH pounds. Is the fuel line kinked to that carb or just looks that way in the picture?
Old 02-09-2019, 02:07 PM
Bhebert449
Bhebert449's Avatar
the fuel line is bent a little bit not kinked. Is there any adjustment necessary to the carbs after replacing the gaskets or just remove and replace? Is there a gasket rebuild kit available?
Old 02-09-2019, 02:15 PM
3X2
3X2's Avatar
At the minimum float level, idle speed, and mixture screws. Have you converted to manifold vacuum from ported for the vacuum advance? Contact Lars, here on the forum, for his tuning guides. Is yours a 400 or 435 engine?
Old 02-09-2019, 02:21 PM
Bhebert449
Bhebert449's Avatar
this sound like it will be beyond my capabilities. Should the carb be rebuild with new all new gaskets? Looks like the fuel is coming out from within the carb and not at the base where it attaches to the manifold. Are there internal gaskets?
Old 02-09-2019, 02:37 PM
3X2
3X2's Avatar
Yes. float bowl, accelerator pump, metering block, throttle plate and probably more than that. I had Eric go through my trips a few years ago and they are still running perfect. He is at http://www.vintagemusclecarparts.com/ Eric actually installs and sets up each carb on a running engine.
Old 02-09-2019, 03:04 PM
Bhebert449
Bhebert449's Avatar
cool. thanks. Mine is a 400hp. I’ll reach out to Eric. I suppose I would just need to remove and ship. Any idea of a ballpark price for the rebuilds?
Old 02-09-2019, 08:33 PM
sug
sug's Avatar
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
If you do it your self get three Holley 37-396 renew carb kits , worked for me and be carful taking your fuel lines of your carbs .
Old 02-09-2019, 09:31 PM
3X2
3X2's Avatar
I'll have to dig out the receipt, but best to ask Eric. It was well worth the money.
Old 02-10-2019, 05:16 PM
Bhebert449
Bhebert449's Avatar
Thanks to everyone for the feedback. I decided to remove the carbs and am sending to Lars for rebuild. Do I need to do anything to protect the exposed manifold ports on top of the engine? Pic attached.
Also since the carbs are removed I would like to clean up the engine a bit. Also considering replacing the the head gasket as I believe there is a leak in the rear next to the firewall. I notice oil pooling under the distributor. Anything else I should go through while carbs are removed?
Old 02-10-2019, 09:05 PM
stumpshot
stumpshot's Avatar
Stuff some shop rags (clean) in the carb ports. Make sure you have a head gasket and not a valve cover or intake gasket leaking. If I were pulling one head I'd do the other at the same time. Your call though.
Old 02-10-2019, 09:08 PM
Bhebert449
Bhebert449's Avatar
Yes I meant intake manifold gasket.
Old 02-10-2019, 09:50 PM
TimAT
TimAT's Avatar
Before I got all excited about pulling the intake, I'd check the bolts == make sure they are nice and tight- be careful of the 4 bolts that are higher on the manifold than the others- one of them is just below the PCV hose in your picture-- it's VERY easy to snap an ear off the intake.. Wash things down with Brake cleaner or something and keep an eye on where the oil is coming from- it's possible that oil is wicking up the threads on one of the bolts- and very common. Cover the intake with clean rags as suggested- I use rags for a short term cover- any longer and it's my favorite is blue masking tape.
Old 02-11-2019, 12:34 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
That is an aluminum intake. Make sure you are applying bolt torques meant for aluminum....not for steel. Also, use duct tape to seal off those openings. Even cloth can tear and end up in your cylinders. Might not hurt much...but ??? Clean the surface with volatile cleaner before putting tape down...or it won't stick.
You can't do any better than having Lars rebuild your carbs. Also ask his advice on how to detail the stuff you didn't send him. He knows all the 'tricks' and how to make that system look new.
To Fuel leaking from carb
Old 02-11-2019, 01:39 AM
lars
lars's Avatar
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes on 1,931 Posts
Brian is sending his carbs out to me, and I'm building a test fixture so I can run and test the Tripower setup on my test engine. I'll post up some photos and progress report on this rebuild as it happens...
Lars
Old 02-12-2019, 07:34 AM
derekderek
derekderek's Avatar
Received 3,388 Likes on 2,633 Posts
Might be easier to do 2bbl to 4bbl adapter and run them 1 at a time.
Old 02-12-2019, 02:02 PM
OldCarBum
OldCarBum's Avatar
Received 4,698 Likes on 2,938 Posts
An old timer once told me to never use a cloth towel or rag to cover, or stuff one in, an engine opening.
He said that strands from a cloth towel could do serious damage to an engine if some get inside.
He always used paper towels as he said the paper fibers would do no damage in the oiling or water systems and would simply burn if they got into the combustion chambers.
Sounded reasonable.
Quick Reply: Fuel leaking from carb
