New carb spacer fabricated
Old Feb 22, 2019 | 03:22 PM
Günther-C3's Avatar
Günther-C3
Default New carb spacer fabricated
Hello!
Needed a carb spacer with the opportunity to mount the accelerator cable. Couldn´t find anything that fits my application, so I fabricated my own.
Günther
Old Feb 22, 2019 | 03:26 PM
ddawson's Avatar
ddawson
Nice but need bigger pictures to appreciate the work LOL.
Old Feb 22, 2019 | 03:54 PM
cv67's Avatar
cv67
St. Jude Donor '05
Nice job.....looks great!
An inner (2nd) return spring is cheap insurance for surprises.
Old Feb 22, 2019 | 05:16 PM
ajrothm's Avatar
ajrothm
Nice job!!!
Old Feb 22, 2019 | 05:38 PM
76strokervette's Avatar
76strokervette
Originally Posted by ajrothm
Nice job!!!
Old Feb 22, 2019 | 05:41 PM
derekderek's Avatar
derekderek
And if you don't have the setup to fab the spacer... https://www.google.com/search?q=holl...Jvc5PHL0-S-VEM
Old Feb 22, 2019 | 05:50 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Outstanding. CNC or manual mill?
Old Feb 22, 2019 | 06:50 PM
Mooser's Avatar
Mooser
M
Old Feb 22, 2019 | 09:02 PM
C3 Stroker's Avatar
C3 Stroker
Outstanding!
Old Feb 23, 2019 | 12:23 AM
gkull's Avatar
gkull
Originally Posted by Günther-C3
Hello!
Günther
Gunther, I was again in Salzburg last fall and didn't have the time to hunt for you
Very nice and clean instead of milling out the plenum divider
In my opinion.... of watching air fuel ratios and trying to figure out how to adjust carburetors and from people much more technically advanced than me. Determined that having a big 3/8ths Pvc to the valve cover leans out the air fuel ratio with polluted crank case air at high vacuum cruise throttle opening and does nothing at wide open throttle with no vacuum when you get the most blow by around the pistons rings
It makes correct carb jetting nearly unabtainable when you watch it on a dyno with oxygen sensors
Vented valve cover breather are better followed by vacuum pumps and the highest quality is dry sump with adjustable crank case vacuum levels up near 18 inches of vacuum actually create more Hp and correct air fuel ratios
I use a breather on each valve cover
Old Feb 23, 2019 | 02:49 AM
Günther-C3's Avatar
Günther-C3
Cnc
Old Feb 23, 2019 | 02:52 AM
Günther-C3's Avatar
Günther-C3
Hi George!
I also don´t like the PCV hooked up to the carb. I´m searching right now the sense of this valve. If I don´t need it, I will go with a breather.
Günther
Old Feb 23, 2019 | 02:53 AM
Günther-C3's Avatar
Günther-C3
It´s thight under the hood, but it fits!
Old Feb 23, 2019 | 07:04 AM
gkull's Avatar
gkull
I hope that you have solid non breakable motor mounts. Years ago I thought that I had upgraded my vette motor mounts to something much better than stock
Energy Suspension red poly locking motor mounts. Then I was out raising hell with my little 427 small block and 5 speed. I had the throttle blades wide open going around a large sweeping turn when I realized that I didn't have any steering. The driver side motor mount had broken allowing the motor to lift up and wedged the headers against my steering rag joint, locking up my steering wheel
You have a 489 ci be safe
Old Feb 23, 2019 | 07:09 AM
69ttop502's Avatar
69ttop502
Very nice work indeed!
Old Feb 23, 2019 | 09:41 AM
Günther-C3's Avatar
Günther-C3
Yes, solid motor mounts installled.
To New carb spacer fabricated
