Rear Spindle Endplay
Old Feb 22, 2019 | 06:54 PM
BlueL82's Avatar
BlueL82
Default Rear Spindle Endplay
I have the setup tool and new spacers + shims but I cannot get the endplay below .005. Is it okay to sand the shim or spacer? The book allows .001-.008 but I've heard the ideal is around .001-.003.
Old Feb 22, 2019 | 08:27 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Yes you can sand the shim. Use the paper on a flat surface and work it in different directions making sure that you keep it even.
Old Feb 22, 2019 | 10:07 PM
GTR1999's Avatar
GTR1999
The shims in the kits are not close enough to dial in a tight endplay. The best way to do them is to use a surface grinder to dial them in.
Old Feb 22, 2019 | 11:10 PM
20mercury's Avatar
20mercury
Default a piece of glass pane is great for this.
A piece of glass pane is great for this. Agree, sand in different directions.
To Rear Spindle Endplay
