Vacuum filter direction?
Old Feb 28, 2019 | 04:13 PM
Factor's Avatar
Factor
Default Vacuum filter direction?
Hi all!
needed to replace the white vacuum check filter that comes directly off the carburetor and goes to the vacuum lights on a 1969.
What direction does it need to face-meaning what flow of vacuum do u want open and closed?
so which way do we want to PREVENT flow...back towards the engine?
thanks!
Old Feb 28, 2019 | 04:54 PM
Mooser's Avatar
Mooser
Engine pulls vacuum so it has to allow flow TO the engine
M
BTW, the check valve is the 3 pipe one (single to the engine) and the filter is the white plastic one, doesn't matter the direction IIRC
M
Old Feb 28, 2019 | 11:10 PM
Factor's Avatar
Factor
Hey Moosser!!! Thanks as always!
lit is the Plastic piece. So allow flow TO the engine. Stopping from going away from engine. (One way open TO engine). I believe I got it.
BTW. If we are not being purists. I found a black DORMAn. #47170. $5. Not original look. But the black looks better.
Old Mar 1, 2019 | 07:28 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
As a note....be weary of aftermarket check valves, I bought a new one from a Big Box Vette outlet and it is like it is partially blocked.....lets very little vacuum through.
Jebby
Old Mar 1, 2019 | 08:24 AM
Factor's Avatar
Factor
Thanks! Will watch for that!
Old Mar 1, 2019 | 01:33 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Again, the plastic filter is not a one way valve.
Old Mar 1, 2019 | 04:51 PM
Mooser's Avatar
Mooser
Just so we're all on the same page
Check valve on the left, single tube to the engine, (on the other side, one tube to the reservoir and the other to the headlight switch)
Filter on the right, doesn't have a direction, works either way
M
Old Mar 1, 2019 | 04:52 PM
Mooser's Avatar
Mooser
Old Mar 2, 2019 | 04:37 PM
Factor's Avatar
Factor
A filter? So what does it do then...? (Besides acts as a. Filter).
mine broke open. So I have 2 pieces. No clue if there is something inside. All I get when I go WOT is 2 pieces~ it just pops apart. If there was something in there. It isn’t anymore.
Old Mar 2, 2019 | 04:39 PM
Factor's Avatar
Factor
Also. I thought the vacuum built up and was stored In The reservoir. ?
thanks!
btw. It is a 468 w big cam. So no real vacuum anyway.
Old Mar 2, 2019 | 04:46 PM
Mooser's Avatar
Mooser
The filter is just there so no debris (rust, etc) from the rest of the system (headlight actuators, valves, tank, etc), doesn't get sucked into the engine, those vac ports lead to the combustion chambers.
The engine is always pulling vacuum (what it can anyway) and the reservoir just give it enough volume (or lack of volume...) to activate the headlights etc otherwise they would be really slow as the engine tried to draw all that "air" out of the actuators a little at a time. Same like the brake booster reservoir, needs a bunch of volume at once
M
Old Mar 2, 2019 | 04:48 PM
Mooser's Avatar
Mooser
Oh, and also lets you lower the lights after you shut the car off... or should be enough stored (un-stored?) for it to close them
M
Old Mar 3, 2019 | 10:03 AM
Factor's Avatar
Factor
Thanks! Yeah I have barely any vacuum w the big cam.
Bc I don’t produce any vacuum. For brake booster, I installed a bandit vacuuum pump. Works like a dream.
So so it is just a filter. Thanks!
Old Mar 5, 2019 | 09:48 AM
Factor's Avatar
Factor
Would be chance this one way valve help retain more air in the system?
Old Mar 5, 2019 | 02:36 PM
pws69's Avatar
pws69
Yes - it attempts to "balance" things when in low vacuum situations
To Vacuum filter direction?
