A/D drain
Old Mar 4, 2019 | 10:08 PM
puzzigully's Avatar
puzzigully
Default A/C drain
Hi Guys,
down here in the southern Hemisphere, we are suffering through 100+ degree days
I know you guys are going through some cold weather, but hopefully you can recall how your A/C works
1978 L82 Pace Car.
When driving with the A/C on for a while, I stopped and looked underneath the car and noticed water (obviously condensed from the air) running out of the plastic molding near the passenger front wheel.
What concerned me was it was coming out between the join of the "box" and not out a drain pipe/tube.
I couldn't immediately see where or if it had a drain pipe/tube...
Can someone please point me in the direction of how the condensed water is supposed to drain away from the car?
Old Mar 5, 2019 | 11:25 AM
MelWff's Avatar
MelWff
You should see a drain under the evaporator core in the engine compartment.
https://www.paragoncorvette.com/p-35...e-w-clamp.aspx
Old Mar 5, 2019 | 04:45 PM
puzzigully's Avatar
puzzigully
Thanks for that....
Maybe I need to take a better look as I didn't see one..
Do you know where it is located?
Cheers
Old Mar 5, 2019 | 06:22 PM
kanvasman's Avatar
kanvasman
from under the car look up to where the heater hoses come out of the heater box. There should be a third hose or nipple hanging down, that is the AC condensate tube. Sometimes those tubes get plugged up or maybe the water is coming out but just running along the frame before it falls to the ground.
Old Mar 5, 2019 | 10:07 PM
jackson's Avatar
jackson
Southern Hemisphere Coriolis Effect Gone Rogue
Old Mar 5, 2019 | 10:37 PM
puzzigully's Avatar
puzzigully
Its more than that...I have to drive it on the wrong side of the road...I can tell it hates it
To A/D drain
