No dash or console lights
Old Mar 9, 2019 | 10:03 AM
82ndABN-C3's Avatar
82ndABN-C3
Default No dash or console lights
I was driving my 72 the other day but got stuck at work and had to work late. Well on the way home I noticed that I had to gauge or console lights . The lights on the radio still work . Checked fuse and it was good . Were else should I look? I’ve read it could be the headlight switch. Please help !
Marc
Old Mar 9, 2019 | 11:50 AM
MelWff's Avatar
MelWff
did you try turning the headlight switch clockwise and counterclockwise to see if there is one or more spots where the lights come back on?
Old Mar 9, 2019 | 12:29 PM
82ndABN-C3's Avatar
82ndABN-C3
Yea I tried that as well, the door lights come on but still no dash. I’m lost hahaha
Old Mar 9, 2019 | 01:22 PM
Batty Mantis's Avatar
Batty Mantis
Do your running lights work? (ie: taillights, side marker lights)
Old Mar 10, 2019 | 11:02 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Check your fuses and check the tail lights. I lost all that as well and have to check my fuse block. I had everythiing die this past summer and had to jump power because I had a dead fuse ( no power to it). Another thing on my winter list that I forgot about......damn I'm only 53 and cant remember anything.
Old Mar 11, 2019 | 12:33 AM
Batty Mantis
I had an issue where my instrument lights, taillights, and side marker lights wouldn’t work. Headlights, interior lights, and brake lights all worked fine. Checked power at the fuse box. Had power running to the taillight fuse but not the instrument lights fuse. It turned out to be the headlight switch (a common problem on these cars from what I hear). Replaced it with a new one. Now everything works fine.
Old Mar 11, 2019 | 10:48 AM
Peterbuilt's Avatar
Peterbuilt
Remove the fuse and test for continuity.
Reinstall fuse and test on the 'CLIPS' that you have power in and out.
TAIL light fuse feeds the INSTRUMENT fuse so make sure TL fuse is good.
Testing the rheostat:
Jumper from 'Courtesy' light fuse to the 'instrument' light fuse.
If the dash bulbs light up the rheostat in the headlight switch is bad.
72 schematic:
https://docs.google.com/viewer?a=v&p...GE5N2EzZGI2Mjc
To No dash or console lights
