1976 front rotor replacement
Old Mar 10, 2019 | 03:41 PM
Ramirez1976's Avatar
Ramirez1976
Default 1976 front rotor replacement
My front rotors need to be replaced. Does anyone know of some good affordable rotors with hub attached? I can't seem to fine any with the hub attached.
-Ben
Old Mar 11, 2019 | 05:31 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Ben,
I’ve never seen an ad from a vendor for rotors with the hubs riveted to them. Normally the rivets are drilled out on your hubs and the rivets are removed. After that you can just replace the rotors. The rotors must be checked for runout. The issue is that the C3 calipers are solid mounted, not floating. If you have excessive runout on the rotors, it will affect your brake performance.
Bob K.
Old Mar 11, 2019 | 06:14 AM
Duke94's Avatar
Duke94
Rivet removal video.
Old Mar 11, 2019 | 07:06 AM
GTR1999's Avatar
GTR1999
That video is ok but there is no mention of deburring the hub or new rotor which will need to be done. You don't need a Bridgeport or even a drill press to do this job. Just a center punch, center drill, 1/4" bit, 5/16" bit, cold chisel, hammer, die grinder. To do it like I do you will need a good indicator, flat heads, countersinks, tap and shims. Depends on what you want- good or the best both will work.
Here is how I do them, if you take your time you can do a very good job that is as good as original.
https://www.digitalcorvettes.com/for...ad.php?t=77063
Old Aug 6, 2019 | 05:08 PM
Chet3's Avatar
Chet3
So easy a caveman can do it! Thanks for the info and your time.
Old Aug 7, 2019 | 07:19 AM
GTR1999's Avatar
GTR1999
Maybe it will be the next Ins commercial !
To 1976 front rotor replacement
