C3 Y pipes
https://www.paragoncorvette.com/c-22...aspx?pagenum=1
https://www.zip-corvette.com/catalog...Exhaust+Y+Pipe
Some list them as the same...
https://willcoxcorvette.com/corvette...e-front-y-only
It appears there are different size pipes (2 1/2" or 2 1/4") and a different flange for the catalytic converter.
You might want to call one of them and ask.
Paragon Corvette Reproductions 1-800-882-4688
Willcox Corvette Sales and Information: 1-812-288-7103
ZIP Products 1-800-962-9632
Good luck... GUSTO
The system:
https://www.corvettecentral.com/c3-6...f%3fcount%3d18
The no a.i.r. front y pipe:
https://www.corvettecentral.com/c3-6...40%26count%3d9
and here is the one with a.i.r.:
https://www.corvettecentral.com/c3-6...39%26count%3d9
I mention corvette central because last year I went back to Ramhorns and installed the 2.5" stock exhaust system (well just about, I installed 64-65 2.5" front pipes) all the way back including the mufflers and it fit like a dream.
You will note in the description that part number "323740 1975-1979 All Front Y-Pipe (2Piece"...... Anyway, if you give them a call, and the fit of mine is typical, then they should probably know.
