Power window help
Old Mar 21, 2019 | 10:04 AM
Osvaldo Berger's Avatar
Osvaldo Berger
Cruising
Default Power window help
Hi all, I'm having some issues with my power window. When I bought the car they weren't connected. First of all I tested the motors with 12V directly and they work perfect, however they are Bosch FRE 12V and not the original ones. After reading a lot from Wilcox and this forum, I followed all the instructions to check the electrical scheme and test the circuit breaker, relay, and switches with a 12v light screw and everything seems to work, or at least turn the light. Nonetheless I have power from the switches to the motor, they are no able to function from the circuit power.
Any idea about what this can be? good motor, apparently good electrical circuit but not working together?
I want to try to fix myself the problem, because this is where I found the fun!
Thank you!
Old Mar 21, 2019 | 12:23 PM
stumpshot's Avatar
stumpshot
Possibly a broken wire where the door and frame meet. Wiring is in a bellows. Old wires that have been flexed a lot tend to break in that area.
Old Mar 21, 2019 | 05:28 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Thank you!
What year is the car... that'd be a huge help in me knowing a way to steer you.
Willcox
Old Mar 21, 2019 | 06:15 PM
Osvaldo Berger
Cruising
Of course, it's 76. Thank you for your videos and especially for your tech section in your web! it has been a great help for me.
I was thinking in change all the cables for new ones because they look really old and maybe some of the currents is being lost or there is too much resistance.
Old Mar 21, 2019 | 07:11 PM
0Willcox Corvette
Former Vendor
If you follow the instructions below.... to a T... you'll figure your issue out....
Willcox
Old Mar 22, 2019 | 03:37 AM
Osvaldo Berger
Cruising
I followed all that instructions and there is power I all the circuit but motors not running. With direc 12v they run.
Old Mar 22, 2019 | 11:03 AM
henrikse's Avatar
henrikse
It sounds like you may have problems with a wire. You can read 12 volts but may not be able to carry current. If a wire is almost broken (lets say two strands out of 12 )you will read voltage but when there is a draw for current it will not pass. Check all the wires for cracking or partial break. You can use an ammeter to check for current along path but will have to be a good one as may be up to 30 amps. good luck
Old Mar 22, 2019 | 11:12 AM
0Willcox Corvette
Former Vendor
Did you run a jumper ground to the motors? Does the amp gauge (battery) deflect when you push the switches?
Old Mar 23, 2019 | 04:19 PM
Osvaldo Berger
Cruising
Yes! and It works! I grounded the motor direct from the battery and connected one of the wires from the switch and the motor workes! So the issue seems to be ground to the motor.
According to the wiring diagram, I only see ground in the circuit in the relay and I think that ground it's working because the relay seems to work fine. (I assume) Following your instructions I can´t test terminal F removing the connector because I have only one connector for E and F.
Do you think it goes something to be with the old wires? both conducted the 22 V to the motor.
My multimeter reading was: battery 18V, Relay 21V, Switches 22V, wire at motor 22V Is it normal? more than the car battery?
Thank you so much again for all your help!
To Power window help
