How accurate do you need it to be? Do you need to fight a speeding ticket issued on private property?
A GPS speedometer app on your phone can get you dialed in to a fraction of an MPH. I use "SpeedOverlay" when biking. It's also handy to calibrate vehicle speedometers.
Funny... i posted this in another thread last night. The speedo calibration chart from the AC Delco book states that the margin for error on most speedometers is 3-5 mph at any given point. Crazy I know... Some had a tighter range but this was pretty much the given.
I know most of these old speedometers can be dialed in close at lower speeds, but most of them start to get off as you go faster. The speedo in my 75 Vert is almost dead on up to 60 MPH since I calibrated it, but it starts reading slow after 60. I know this is backwards from what I have seen in the past and what most people report. My transmission was setup for the 3.08 gears and I have 4.11 in this car. I changed the drive and driven gears both to get it right.
In response to Ernie's post, I know the federal government used to recommend a 5 MPH leniency for speeding tickets. I don't know if that is the case anymore.
Mike
Mike
Mike, a rule of thumb I heard many years ago is 10%. It has worked well for me all over the country, that and making sure I'm not the one leading the pack....
The only exception I've encountered is on most military installations. If the limit is 25, it's 25, not 27, or 26, it's 25! After 31 years of active duty, I learned well there are few things more dangerous (or lacking in common sense) than a 19 year old with a gun and a badge!
Except for the one time I got pulled over while cruising in downtown Sioux Falls in the late 60's for doing 1 mile over. I've never been stopped as long a I stay under 10 over on the highway or interstate. When I got stopped back in the 60's for 1 mile over, it was just an excuse to pull us over to see if we were drinking or smoking anything. I didn't get a ticket.
My 72 is +/2 most of the way from 10 to 60ish then it gets in the + bracket and is +5 at 75. I'm going 75 it says approx. 80. My 71 is low up by 1 or 2 up to approx. 70 then is + 2 to 4 after that.
