Torque converter will not unlock car bogs and stalls at low speeds. All stock and trans is rebuilt. trans shop says its in the car. I checked the brake switch and it is working. Any ideas.
Either voltage is contstantly being supplied to the Lock-up function of the torque converter, or the unit has sustained mechanical damage from not being used properly (via a lockup controller). That L/U clutch was never meant to pass significant torque through the transmission. The 12vdc signal to engage that clutch MUST be dropped when throttle is increased in upper gear ranges. If not, it will eventually fail. Pull the L/U power connector out of the transmission, then drive to see if it is still engaged. If it is, take the car to the transmission repair shop.
Could be a problem within the ECU... or, it could be something amiss with a signal coming in to the ECU. I might suggest that you eliminate the possibility of bad electrical ground or 'dirty' connections by removing all such connectors and terminals, cleaning them, then replacing and trying it again. (Easy fixes are always better!)
ok i have removed all the brake switch plugs 3 each and the egr/tcc relay plugs and I still have 12v at the trans plug pin A. Where is the TCC relay located I have the two relays disconnected from the back of the pass side valve cover but it appears I am missing one that should have a purple wire coming from brake switch.
I still have the belief that the ECU makes the decisions about L/U being On or Off. Does the power from the brake switch go directly to the L/U connector at the trans, or does it get fed to the brake lights and the ECU? IMO, the problem could be with a relay (driven by the ECU), or by an errant ECU signal to that relay.
Pin A should have 12V with the ignition on. Unless you have 12v there at other times then don't worry about it. The Solenoid is controlled by switching the ground to it via the relay.
The TCC relay is on the drivers side. You should have a bracket with two relays and the vacuum sensor mounted to it.
This Relay is controlled in two ways: The purple wire from the brake switch switches +12V to the relay, while the ECU switches the ground.
Relay connections are A - Ground
B - Switch ground via ECU (coil-)
C - Switched 12V via brake switch (coil+)
E - Switched ground to EGR/TCC solenoids.
How important is having the lockup to you? My 80 doesn't have an ECU but still has lockup via brake and vacuum switches. I ran into issues with the port in the solenoid in the trans clogging up. I finally pulled the solenoid from the valve body so lockup was disabled and never looked back.
The problem with eliminating the L/U function is that the transmission is going to overheat. With L/U engaged, there is little work done by the converter...hence, little heat build up. But, the converter is constantly slipping (ie, working) and generating more heat than the [transmission] cooling system is capable of providing. If you do this, you need to add a trans cooler in the system. It would be easier to fix the L/U problem.
