Headlights Are More Like Strobe Lights!
Old Mar 27, 2019 | 10:06 AM
dant849's Avatar
dant849
Default Headlights Are More Like Strobe Lights!
Morning to everyone...1979 Coupe, had no headlights. Replaced the engine harness and the forward lights harness. Worked perfectly for a minute or so, then started blinking erratically. Cut em off, wait a minute, turn them back on. Perfect for maybe 30 seconds, then the light show begins again. I've checked the grounds on the new harness and the headlight switch is new...what am I missing? Thanks in advance!
Old Mar 27, 2019 | 10:11 AM
Kacyc3's Avatar
Kacyc3
the headlights use a circuit breaker not a fuse. The blinking is them overloading the breaker and it tripping, add a relay with a fuse to power the lights, you will have brighter lights, less load going through the switch, less chance for melting the switch and stop the blinking.
Old Mar 27, 2019 | 10:30 AM
speedreed8's Avatar
speedreed8
Look up Daniel stern lighting. He has relay kits to fix the problem. I have relays for the lights on my 79. Work great brighter headlights because they get power straight from the alternator 14V
Old Mar 27, 2019 | 10:50 AM
mbp's Avatar
mbp
Hi. I had that problem as well after I replaced my Headlight switch on my 69. It appears not to be uncommon, some of the switches seem to "over heat" and kick on and off. I know there is a technical term for what it is in the switch that's screwing up, just can't remember what it is. Returned switch and got another from a supplier and it worked fine.
Old Mar 27, 2019 | 11:21 AM
7T1vette's Avatar
7T1vette
I highly suspect that mbp is on the right track. The C3 headlamp electric circuit passes all the lamp current through the headlamp switch. The contacts get 'dirty' over time because of arcing, etc. Your best option (every C3 owner's best option, actually) is to install relays into the circuit so that the switch only turns on the associated relay (HI or LO beam lamps). You could leave current for the parking lamps at the switch as it is relatively low current; or you could also add a relay for those.
I don't drive my car much at night; but I have noticed some amount of heating at the switch area and lights are not as bright as they should be. So I need to do this same 'upgrade'.
Old Mar 27, 2019 | 03:13 PM
dant849's Avatar
dant849
Thanks for the input. The switch is new but we know that doesn't mean its good...I still have to install the starter harness, maybe that will reveal something...oh, and now it's only strobing on high beam...
Old Mar 27, 2019 | 03:16 PM
sstonebreaker's Avatar
sstonebreaker
Might be the circuit breaker that needs replacing...
Old Mar 28, 2019 | 08:49 AM
jb78L-82's Avatar
jb78L-82
The headlight switch is the circuit breaker all in one. If the old headlight switch did not trip the breaker, then the new switch is bad or there is a wiring issue.
I have had 4 Hella Euro Halogens on my 78 since the late 80's, 55/60 watt H4 lows and 100 watt H1 highs. I had to wire a relay in at that time for the highs only to remove the current draw from the switch to prevent the lights flickering. Only the highs are on a relay, the lows run through the switch.
FWIW-the relays may help a sealed beam headlight look slightly better but do not expect miracles with light output. My Lows on the light switch (no relay) do not show any significant amperage drop versus the relay used with the (2) 100 watt highs. The purpose of the relay is reduce the amperage load on the switch and as long as the amperage is reduced either using a relay for both low and high OR either one but not both, the light circuit will be bright and good to go.
Old Mar 28, 2019 | 10:32 AM
dant849's Avatar
dant849
Thanks for that explanation! So if I understand you, the high beams run through a relay. If I'm only flickering on high beam, could it be that said relay is bad? I don't know the status of the old headlight switch because the lights didn't work when I got the car. I bought a new switch just because...
Old Mar 28, 2019 | 10:41 AM
Kacyc3's Avatar
Kacyc3
No he said he wired in a relay for the high beams, your car doesnt have that relay, the headlight switch is the circuit breaker.
Old Mar 28, 2019 | 10:42 AM
jb78L-82's Avatar
jb78L-82
If the lights are only flickering on high beam, then the highs are exceeding the amperage rating of that switch. Put a relay on the high beams only and the problem will be solved......
Old Apr 2, 2019 | 11:27 AM
79 Money Pit's Avatar
79 Money Pit
3rd Gear
Had a similar problem on my 79 when I changed to halogen bulbs. I had also replaced the headlight switch. Check you light bulb connectors as well. My one high beam connector the wire on the back was exposed causing a current draw.
Old Apr 2, 2019 | 04:37 PM
lionelhutz's Avatar
lionelhutz
The root cause of the problem is either a bad headlight switch (the circuit breaker inside is bad) or the car has higher than stock rated wattage bulbs in it.
To Headlights Are More Like Strobe Lights!
