Front rotor thickest??
Old Mar 31, 2019 | 03:52 AM
nz corvette's Avatar
nz corvette
Default Front rotor thickest??
Hi Team,using the wealth of experience from this great forum...whats the minimum thickest of the front rotors,mine are 1.24" -good, average or bad?
Many thanks Dave NZ
Old Mar 31, 2019 | 08:38 AM
Street Rat's Avatar
Street Rat
Many thanks Dave NZ
Hello Dave,
The rotors usually have the minimum thickness measurement embedded in the rotor.
I'll go look at some old ones if needed.
Craig
Old Mar 31, 2019 | 08:42 AM
MI81's Avatar
MI81
Hi,
1981 service manual shows Front and Rear specs to be the same.
I believe the same spec applies to all C3's.
Disk original size = 11.75 x 1.25"
Miimum refinish thichkness = 1.230"
Discard thickness = 1.215"
At 1.24" you can still machine your rotors.
Hope this helps.
Old Mar 31, 2019 | 09:19 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The min is 1.215... If it's an original rotor you'll find this on the inside.
Willcox
Old Apr 2, 2019 | 04:40 AM
nz corvette
Thanks Guys,looks like I might have enough to give them a skim
Cheers Dave NZ
To Front rotor thickest??
