77 engine parts torque specs.
Old Apr 4, 2019 | 12:27 PM
Novusuhu's Avatar
Novusuhu
Default 77 engine parts torque specs.
Hey everyone
Where can I find the torque specs for the all the engine brackets, pulleys, etc... bolts?
Can't seem to find them in the AIM.
Old Apr 4, 2019 | 12:48 PM
bmotojoe's Avatar
bmotojoe
Originally Posted by Novusuhu
Hey everyone
If it was attached on the assembly line most of the torque specifications are included in the AIM. If you look at let's say page UPC 9E Sheet 4 item #5 (Nut) you will see a triangle with a 1 inside of it. Now lower left side of the drawing you will see a triangle and a 1 inside it. All torque specs. labeled 1 on this sheet are between 14-20 FT pounds.
You may also see some circles with a number in them on the same line as the torque spec. This indicates a revision, not sure what this means.
Hope this helps.
Old Apr 4, 2019 | 02:11 PM
DAD111's Avatar
DAD111
Hope this helps.
Great post - To add - the revision - means that an item or process has been revised with the number meaning how many times it has changed - At the bottom center of the title block - it will have the number and date it was revised and who revised it along with the description of the revision.
Old Apr 4, 2019 | 11:01 PM
JoeMinnesota's Avatar
JoeMinnesota
Check here: https://www.speedwaymotors.com/the-t...ications/28650
and here: https://paceperformance.com/p-3981-g...que-specs.html
To 77 engine parts torque specs.
