Setting timing on a 77 L48
Old Apr 11, 2019 | 09:47 AM
Novusuhu's Avatar
Novusuhu
Default Setting timing on a 77 L48
Hey everyone
I will (re-)set the timing of my stock1977 L48 with open longtube headers for the first time...
I did some reading, and think I will just have to do the following.
- I have a timing light.
- I have to dial in 36 degrees BTDC on the light, then just set the timing so that the marker on the damper is at "0" on the pointer.... Then I'm OK to go?
Please confirm?
Old Apr 11, 2019 | 09:59 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Yes, with the vacuum hose disconnected from the distributor and plugged. Once set at 36*, reconnect vacuum hose and check timing again. It should read somewhere around 50* at 3600 rpm. Take for a test drive. If you detect any pinging, retard timing by 2* increments until ping is gone.
Old Apr 11, 2019 | 10:03 AM
Novusuhu's Avatar
Novusuhu
What is pinging? Can you discribe it, because I never noticed it in my life...
I just know it is bad for the engine.
Old Apr 11, 2019 | 10:18 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
It sounds something like rocks rattling in a can. More pronounced under light throttle going up a hill. Anyway, you'll hear it if your timing is too far advanced.
***The method I described is just a basic timing procedure assuming your engine is in good mechanical condition***
Old Apr 11, 2019 | 10:23 AM
Novusuhu's Avatar
Novusuhu
So you can only see if your timing is right, when risking a pinging engine?
I read that when your engine is pinging there will be direct damage to the engine?
Old Apr 11, 2019 | 11:05 AM
derekderek's Avatar
derekderek
34°is better with a small block. The extra 2 degrees does not produce any more power. And this timing is at 3000 rpm with vacuum advance disconnected. FIRST check idle timing with vacuum unhooked and again when hooked up. Unhooked you will see mark on tab with light set to 0. Probly hafta dial light back for idle with vacuum. NOW rev to 3000 and dial light til timing mark is at 0. Check dial for timing. Now you know what you had. And you know how much mechanical and vacuum advance distributor has. Now set it to 34 degrees at 3000. Now check new idle timing. Now hook up vac and re-check idle and 3000.
Old Apr 11, 2019 | 02:29 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Originally Posted by Novusuhu
So you can only see if your timing is right, when risking a pinging engine? Back in the day, yes, so some believed. Some guys advanced the timing to the point where it began to ping and then backed it off a degree or two to eliminate the ping.
I read that when your engine is pinging there will be direct damage to the engine? Not necessarily if its not severe but if not corrected, over time it will do it's damage.
As derek said, do this at 3000 rpm. For iron heads, 34-36* is about optimal, depending on the engine - stock or modified. At cruise with the vac can connected, you may or may not experience pinging. That is dependent upon the additional timing added by the vac can and quality of fuel. Set your timing and test drive. Try different timing settings if you like and use your seat of the pants as an indicator for performance but 34-36* @ 3000 rpm without vac can connected is about where you will end up.
Old Apr 12, 2019 | 11:14 AM
TimAT's Avatar
TimAT
From your first question, you stated "open longtube headers". If you have open headers, odds are you won't be able to hear if it's pinging or not. From that, I'd suggest being conservative with timing.
Old Apr 14, 2019 | 10:33 PM
lars's Avatar
lars
I don't see anyone stating this, but the 36-degree timing spec is at maximum, "pegged-out" centrifugal advance, which can be at any rpm between 2500 and 5000 if the distributor has stock springs in it... You can't just set the timing at 36 at any rpm, or at 3000, and assume that the timing is pegged out.Make sure the centrifugal is fully pegged out, and then set the timing at 36. Once done, tailor the springs to achieve this spec at 2800 - 3000 rpm.
Lars
Old Apr 15, 2019 | 07:10 AM
derekderek's Avatar
derekderek
Y'know, I think we all assume those springs are done stretching by 3000. So what, time it to your number at 3k then push it higher while watching the mark for more advance?
To Setting timing on a 77 L48
