72 frame repair question
I am looking for tips/advice on the process.
I do not have a chassis table so my intention was to build a quick supporting structure out of 2x4s and clamp the chassis to it to ensure that once the section is removed, everything stays put. Do you feel this will be sufficient?
Also, there were no instructions included however I have been watching videos and doing as much reading as I can (which actually isn't very much) but the process seems fairly straight forward. I would appreciate the feedback from those who have done this already.
My plan of attack:
1) secure frame to chassis support
2) remove bad section of frame
3) spot weld the inner sleeve to the frame
4) spot weld the replacement frame pieces to the inner sleeve
5) tack weld the replacement frame pieces in place, ensuring straightness.
6) confirm measurements and angles, then finish welding all seams
Is this right?
5)
My neighbor and I put a Camaro subframe on the front of a 52 Chevy Sedan Delivery. No frame table, but we braced and levelled it with stands and shims with 1" square tube. After a whole lot of measuring, we cut the old front end off and put the new subframe in place. All done we cut the bracing off and measured again. Stayed straight. Little grinding and some paint.
Out of curiosity with the frame secured as you mentioned, did you find that it had moved and required adjustment once you cut away the bad sections?
In any case, I want to be absolutely certain that this is a straight repair so I will do as you did with lots of measurements and checking before everything is welded up solid.
i had never done a frame repair like this on a vette and i really didnt like butting inner and outer repair piece to the exisiting frame even with that sleeve, i thought about it for a little and the staggering idea popped in my head and im my opinion thats the best and strongest way to go.
