Wheel Well #3 mount Access Opening
Old 04-15-2019, 07:21 PM
caskiguy
Support Corvetteforum!
caskiguy's Avatar
Default Wheel Well #3 mount Access Opening
#3 PS access top seam has separated. What's the recommended repair procedure (besides using small explosives) ?
Thanks.
Passenger side #3 mounting bolt access panel
Old 04-16-2019, 06:49 AM
PainfullySlow
PainfullySlow's Avatar
I am certain that someone with actual experience will chime in shortly but to me it looks like the bonding material separated in which case it should be as simple as removing the piece, cleaning off the old bonding adhesive, scuffing up both sides, and re-applying new bonding adhesive.
caskiguy (04-16-2019)
Old 04-16-2019, 08:08 AM
caskiguy
caskiguy's Avatar
Old 04-16-2019, 08:38 AM
bazza77
bazza77's Avatar
I have removed 4 original glued on panels and they are a *itch to get off. That's using a heat gun which will destroy your paint on your dogleg if you are not careful. My advice to you is to first break out the 30 or 40 grit and get the black paint off then the pink colour glue to.find the top of the panel which is straight, then try and get the big blob of glue they used as a filler in that area ground down with paper or a diegrinder that has small paper disc on it.
That's what I would do as a start anyway....
Old 04-16-2019, 08:48 AM
caskiguy
caskiguy's Avatar
I anticipated it being no picnic doing a repair on this. If I clean away the old bonding material (top and left side) what is the "new" bonding agent I'd use ? As for getting it to lay against the wheel wheel I believe I can use a 2"x2" cut to length as a brace from rear to front of the wheel well and not have to remove the separated cover.
Old 04-16-2019, 10:22 AM
bazza77
bazza77's Avatar
I took mine off to get at a rusty birdcage mounts easier , I bought enough Lord fusor to rebond all 4 guards and a new hood surround on so I'm just going to use that in there , when I get around to it.
But for a once off maybe a smaller tube of sikaflex ,as long as you have no plans to get it off ever again!
Old 04-16-2019, 02:36 PM
caskiguy
caskiguy's Avatar
Sikaflex 291 ?
Old 04-16-2019, 10:46 PM
bazza77
bazza77's Avatar
I was just looking at CraigH,s 71 resto thread and he used 227 , he certainly knows what he is doing !
caskiguy (04-17-2019)
Old 04-18-2019, 06:56 PM
gmmeyerIII
gmmeyerIII's Avatar
i used 3m. worked great
https://www.amazon.com/gp/product/B000PEW4MI/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000PEW4MI/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
caskiguy (04-18-2019)
Old 04-18-2019, 07:45 PM
Buccaneer
Buccaneer's Avatar
Location: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Received 1,010 Likes on 691 Posts
Originally Posted by gmmeyerIII
That stuff is awesome and will work great. However, you will need a gun with that and it isn't cheap for a one time kind of job, but like I tell the wife when she asks about why I need to buy yet another tool...It's because when you need it you need it and when you don't have it is when you need it no matter how many times it gets used after that. At some point I will have to do my body mounts as well, just kicking the can down the road some more.
Old 04-18-2019, 08:52 PM
caskiguy
caskiguy's Avatar
Outstanding ! Thank you and Thank God for Amazon ! LOL !
Old 04-18-2019, 08:53 PM
caskiguy
caskiguy's Avatar
One can never have enough tools !
Bought the 3M kit.
Thanks for the help.
Old 04-18-2019, 08:54 PM
caskiguy
caskiguy's Avatar
227 arrived today. Thank you.
To Wheel Well #3 mount Access Opening
Quick Reply: Wheel Well #3 mount Access Opening
