Jack stands
Old Apr 24, 2019 | 07:23 AM
Mooser's Avatar
Mooser
Not sure your location (you should ad that and the car year to your profile so we can see it)
The 6 tonne HF stands are about $50 and are fine, frequently on sale or use the coupon.
M
Old Apr 24, 2019 | 07:25 AM
mark79,80's Avatar
mark79,80
Walmart has 6 ton jack stands that can be ordered with free shipping and are under $40 a pair:
https://www.walmart.com/ip/Pro-Lift-...-Ton/575652534
The ones shown have a locking pin, in addition to the latch which is a nice safety feature.
Old Apr 24, 2019 | 08:16 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Originally Posted by Bhebert449
The flat tops on those jack stands are better when placed under the flat areas of the frame. I would buy two pair of those and one pair of the other style. Stands are not expensive.
Old Apr 24, 2019 | 08:39 PM
GUSTO14's Avatar
GUSTO14
Northern tool has an excellent selection of garage tools that are reasonably priced. Many are name brand. They currently have a pair of Hein-Werner 3-Ton Jack Stands for $75. They have some less expensive and lighter duty stands as well. Keep in mind 4, 3-ton stands can theoretically handle 24,000# and 4, 2-ton stands, 16,000#. Just about any set you have posted can do the job you're planning to do.
One thing to keep in mind when using jack stands is they like being on a flat level surface sturdy enough to support the. If you find it necessary to use them on a dirt surface, be sure to use a large enough piece of wood (2"X12") to support each of the legs at the same time. Be reasonable on the height you extend the stands and avoid pushing and shoving on the vehicle while it's up in the air. I keep a couple of 12" lengths of 8" X 8" timbers to place under the vehicle strategically (under a crossmember, frame section, differential) to capture it in the event something did fail.
Good luck and be safe... GUSTO
Old Apr 24, 2019 | 08:43 PM
GUSTO14's Avatar
GUSTO14
Yes they do, Northern has them available for $70 each. A bit pricey, but a good looking stand.
GUSTO
Old Apr 25, 2019 | 08:03 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Speaking of safety, when I get my car up on the 4 stands, I go to each corner of the car and give it a firm shake. Better to fall off the stands shaking the car than being under it if a jack(s) fails.
Old Apr 25, 2019 | 09:41 AM
htown81vette's Avatar
htown81vette
After many years of using jacks/jack stands I invested in the Dannmar MX6 garage lift. Worth every penny, makes life so much easier.
Old Apr 25, 2019 | 03:01 PM
Bergerboy's Avatar
Bergerboy
I just got set-up with a QuickJack.
Also very nice.
Old Apr 25, 2019 | 04:31 PM
cv67's Avatar
cv67
St. Jude Donor '05
With the others, not comfortable with smaller ones that are extended all the way up. Always have a jack under it just to eliminate Charlie Brown luck.
Walmart sells some nice ramps for $40/pr works with most low sitting cars. iF you cant drive up, then jacking the car up and setting them down on ramps seems safe (Chock tires)
