Distributor question
Old Nov 4, 2002 | 10:05 PM
scottw's Avatar
scottw
Default Distributor question
I have my MSD distributor in and the car is running okay. I have it turned counterclockwise as far as it can go. The vacum advanced is as far to the right as it can go on the intake and the tach cable will not go anymore to the right. I am at about 10-11 degrees BTDC. I would like to advance the timing to about 14 but cant turn the dist. anymore. Could I be one tooth off? Can I readjust the dist one tooth or not?
Old Nov 4, 2002 | 10:07 PM
pingdashf's Avatar
pingdashf
Default Re: Distributor question (scottw)
I have mine rotated just about as far as it can go and am at 12-14. Getting ready to run outside and see if I can bump her up a few more notches, so I'm really interested in some responses to this thread. I'm basically just posting so I can get the email update :)
Old Nov 4, 2002 | 10:10 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Distributor question (pingdashf)
yes pull it out and move it one more tooth and then youll have room to advance it some more.
Old Nov 4, 2002 | 10:23 PM
scottw's Avatar
scottw
Default Re: Distributor question (patsnitrovette)
Just want to make sure. I take it out and rotate it clockwise one tooth correct?
Old Nov 4, 2002 | 11:32 PM
lars's Avatar
lars
Scott -
You're one tooth off. Just pull the distributor straight up until it JUST disengages from the cam gear, and then drop it right back down again. It will jump one tooth over in the right direction, and you'll have plenty of adjustment. By the way - forget about initial timing. Unplug your vacuum advance and use an adjustable timing light on it. Rev the engine up until you don't get any more centrifugal advance out of it (usually about 3000 rpm) and set the timing at this point to 36 degrees. Then hook the vacuum back up.
Old Nov 5, 2002 | 03:20 PM
Tom454's Avatar
Tom454
Default Re: Distributor question (lars)
Hey Lars...
Hope you know that tip is worth $64,000.
You get paid for this, right?
Old Nov 5, 2002 | 03:25 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: Distributor question (Tom454)
Hey Lars...
That's would be about a dollar for every time he has had to give it :lol:
Old Nov 5, 2002 | 03:37 PM
Fevre's Avatar
Fevre
Check to make sure your are one tooth off, you might be one plug wire off meaning you plug wires are all one slot off. Pull you cap and put you car at TDC, the rotor should be pointing right at cyl #1. If it is, then you are one wire off. I guess you dist doesn't have to point at #1 but it is a pretty general rule of thumb. Moving plug wires one slot it a lot easier than aligning that damn oil pump notch. :mad
Old Nov 5, 2002 | 04:29 PM
lars's Avatar
lars
Default Re: Distributor question (Fevre)
Fevre -
When you pull the distributor straight up and drop and right back down, it will line right back up with the pump shaft while moving over one tooth - no need to try to align the pump shaft with the distributor shaft. If you do this repeatedly, you can actually "walk" the rotor all the way around to align it in any position without ever having to worry about oil pump shaft alignment. It works really slick.
Old Nov 5, 2002 | 05:44 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Lars (or anyone else that's very knowledgable of adj timing light).....Will an adjustable timing light work on any mark you put on the balancer? I ask this because my balancer has slipped and I can't read the timing with my old style timing light. If the adjustable will work, I'm headed out to get one tonight. :D
Old Nov 6, 2002 | 12:25 AM
lars's Avatar
lars
Default Re: Distributor question (tshort)
Travis -
You have to know where top dead center is, and this has to be accurately marked. Usually, if the balancer has slipped, you don't know where TDC is, since you don't know how far the balancer has slipped. The adjustable light can't determine this for you. You can use your slipped balancer with an adjustable light as long as you locate TDC and re-mark the balancer. I have a tech paper on how to do this - drop me an e-mail if you need a copy.
By the way - your Demon carb is going in the mail to you tomorrow (Wednesday). I got it running great, so you should have lots of fun with it.
Old Nov 7, 2002 | 05:57 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Thanks Lars!
By the way....if any of you guys don't know about Lars yet, he is Awesome! I don't know anyone else in any other field that does the quality of work with the same amount of professionalism and price (and that's when he's actually charging for his services) and speed that he does.
Here's to you Lars :cheers:
Old Nov 7, 2002 | 06:05 PM
lars's Avatar
lars
Hey tshort -
You better try out that carb I did for you before you start toasting.... maybe I really hosed it... I ran out of gin for my Martinis part way through the building process, and I don't work too well when my blood alchohol level drops too low..... :eek:
Old Nov 7, 2002 | 06:15 PM
tshort's Avatar
tshort
CI 7-8 Veteran
:lol: :lol: :lol:
Old Nov 8, 2002 | 04:30 AM
kingdavidrules's Avatar
kingdavidrules
Scott -
will this work for any engine ? i have a 383 stroker ,hot cam dart2 heads. still cant find that perfect timing . i know when it was set at idle and i retarded it till it "sounded " better .
To Distributor question
