Best C3 Rear Wheel Spindle
Old Apr 28, 2019 | 05:43 PM
Last Special's Avatar
Last Special
Default Best C3 Rear Wheel Spindle
Can anyone recommend the strongest (best) USA made spindle to replace the stock one with high face runout? Should I get a Tom's Differential spindle, or is it better to remove the studs from the stock one and have the face light cut on a lathe to reduce the runout instead?
Old Apr 29, 2019 | 09:50 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Chances are that it is the shaft that has a slight bend causing run out, best to replace. When I was researching axel I found a couple of different stub shaft manufactures that are made here, so do your diligent research I'm sure that you'll find others and also our members will help' T
Old Apr 29, 2019 | 10:51 AM
ajrothm's Avatar
ajrothm
Toms Differentials would be choice 1. Mark Williams would be choice 2. You can never go wrong with Toms stuff though.
To Best C3 Rear Wheel Spindle
