700R4 Conversion Exhaust support
I’m looking for ideals for supporting the exhaust system in the transmission crossmember area. I changed the crossmember to the G-Force bracket, I have stock exhaust manifolds and I’m attempting to re-use me old exhaust system which is 2 ½” pipes.
I do not have a good picture of the bracket, but you can see the way it holds the pipe here:
From the last picture it looks like you have room to fabricate a mount (or modify the stock one) so that you can clamp the exhaust pipes onto it.
Can you get us a snapshot of the rear tranny mount? To see how much room there is towards the exhaust pipes. It took me a few remove&replace times to tweak my modified and NOW forward-facing tranny mount to support the pipes in the correctly centered place in the crossmember exhaust holes. You should have it a bit easier (if there is room) since you're crossmember is a lot better with more room.
https://www.corvettecentral.com/c3-6...c3%26count%3d9
I took my center exhaust hanger and made it face forward, then tweaked, and bent, and kept adjusting it until the 2.5" exhaust pipes were centered in the xmember holes. I actually ended up driiling holes in the exhaust hanger and dropped the clamp legs through there.... just to be able to keep the exhaust pipes centered. With you roomier crossmember you should have a bit more flexibility.
And the other option I found was the 1963 super fancy contraption. It also has the isolater between the bracket and the frame so it would work. Look at the drawing towards the bottomm
https://www.corvettecentral.com/c2-6...r%26count%3d18
And another view showing how it kinda/sorta bolt onto crossmember:
https://www.zip-corvette.com/63-2-1-...anger-kit.html
So you have quite a few options without mounting it rigidly to the frame. And they would be based on the stock system ....
Corvette Central 68-78 trans exhaust hanger
although not the right fit for your TH700, the concept would be similar to fabricate something that attaches to the back of the trans using those bolts. the bracket is steel, long enough, has enough mass for heat dissipation, so that heat transmission to the trans is not an issue (the trans case is already pretty "warm"). the trans is rubber or polymer mounted to the frame, so NVH also isn't transmitted to the cabin.
I did something similar for my TH700 swap, had to do some cutting, sectioning, welding to come up with a bracket. can't take a pic because the car is not on jackstands (being driven).
also, I bought some SS 2.5" very tight bends to pie-section and weld up an S-shaped section of tubing to get around that pass side corner of the trans and still snake it through the stock 2-hole trans crossmember. it's a tight bend, it's a tight fit, wrapped with thermotec, but it fits, it works, no contact anywhere (except the bracket), and it's been on the car for years now. I might've started off with a small radius U-bend. you have to cheat on some of the turns and radius's. but it does make a smooth run around that difficult corner.
just food for thought.
Transmission mount area
OH, total cost for the mods...maybe ten bux......
I am using the arched Bowtie Overdrives 700r4 cross member and the exhaust just goes right under it like this. The only place I have the exhaust hung is off the back bumper.
Now I'm wondering whether they SHOULD have more support... I was just assuming that being connected to the heads on one end and the bumper at the other was "good enough"...
Adam
My first thoughts, I had concerns about stressing the exhaust manifold studs, also the factory exhaust support was in the same area, but attached directly to the transmission (400).
The 700r4 does not have that hold. With the G-Force support & transmission mount area, I just haven’t been able to configure a support bracket that would use the rubber flex of the mount, bracing from the top of the transmission mount.
I attempted not having the middle support, but the rear exhaust hangers allowed the exhaust ends to move side to side, which would claused the factory tips to hit.
