ACI L-88 Flares
I know this subject has been covered to death in the past but with fewer and fewer options for flares over the last several years I’m running into some dead ends. I received my L-88 Flares from ACI and they look pretty good. About 1/8” thick or more too. Upon mocking them up I’m realizing my mudflaps on my 77 will have to be cut before I can even get an accurate reference line on the fender. This is not something that I like, obviously. But I can deal. Anyway... They came with a paper stating to call ACI for all installation and tech questions and they would be glad to help out. Well, I called ACI and talked to Jim. Nice guy, but he told me that he is not familiar with how to install them and his install guy has never installed them either! I’m shocked. This many years and “never installed them”? I find that hard to believe. It makes me wonder what has happened in the past that causes them to take that response. Anyway... So they were very little help. As I get to working with the flares on the body, I notice that no matter how I mock these up, it looks like these flares will need to bond well beyond the fender bond-strip that is on the inside support brace. In other words, it looks like I’m going to have to cut through the bond seem if I wanted to remove all of the fender material necessary for a smooth fender well. I don’t know if I would need to do this, but with as tight as my wheels and tires will be fitting up under there, it is a concern. On top of this, as I’m mocking up the flares I’m not seeing near enough panel-to-flare contact to ensure a proper bond. Maybe 3-4 mm of contact and then it quickly opens up to a very large gap. Worrisome.
I know many have bonded these flares on and have worked them to look all sorts of ways, unfortunately, I’m struggling on finding any advice or details that address my concerns here.
I’ve put in a word with another (out of business) glass company that makes a really awesome fender for these to see if they have a set still left over. If I’m going past the bonding strip, I might as well go with a full panel and not have to worry about working those curves of the flare.
Any advice here on these ACI flares that can help address my concerns from you forum folks?
For those of you that have these flares bonded, could you take several pictures of the inside fender well for me? I would really like to see where and how the fender is bonded and how much material was removed from the mudflap areas.
Thanks for reading,
-Stroke
This is the front on my 80 which required a make mods to fit the different front end. The front of the flare splits in 2 pieces at the seem
The rear flange was yet to be cut down in this image. I have since trimmed the flange back but no recent images. I did have to cut the original mud flap on the rear.
The images above were taken a few years back as since them I have trimmed back the flanges a lot. I wanted them to be bolt on.
The flares started out a quarter panel sections from a company in Louisiana that hasn't been around in a long time. The sections included flares and were supposed to be glassed in. The lower sections needs so glassing/shaping to fit the body tight. I'm not thinking about trimming some of the mud flap as they catch a lot of air or fut an opening in the flap area to add some screen.
First, take them off and sand down your existing fenders (on car) and your new fenders with 80 grit. You could also use a paint stripper if used carefully, despite what others are going to tell you. You need to remove paint on your fenders at a minimum to ensure adhesion and make sure you don't have any filler hidden under the paint. If you do, remove that as well until you have a nice clean surface to glass to. Note, if you do have hidden filler, no big deal, you will be glassing anyway. Just fix that with glass mat as you place your fenders. You don't want filler or paint under your new glass though. You also need to sand your new fenders so the resin will stick to them. If you dont, You will have a large failure on your hands and you will have to sand out all of your hard work.
I used Clecko pins to hold them during mock up, but I suppose tape will work too as long as you have a clean surface prior to glassing. Basically mock the fenders up as you have and then remove your pins/tape in a small area and lay some glass. Let that dry, then move more pins/tape and glass more until you have the entire fender attached. You will then need to add probably 3-4 more layers of glass matt over the area until it is close to looking like you want, sanding between layers of course. By this time you will have sanded more than you want to... Keep going... After you have it glassed in from the outside, go underneath and cut out your old fender. Then glass the inside all up. After laying 3-4 layers of matte under and around, you will have a hard time telling where the old fender was. It should look pretty good at this point. Then time for body filler and LOTS more sanding.
Below is mine both after body filler, then after first coat of primer. The primer picture is before sanding and still a bit rough with some trash and standing fibers showing that I am in the process of sanding out now. This car was sitting in the sun for a long time and needs a bit of extra love. It is a 73 that I removed the rear bumpers and glassed the rear valence into a single piece as well. Don't have any pictures with me of the fenders before filler, but if you look close you can see the glassed in bumper areas that were cut and reglassed.
Keep at it, it is a large job, but looks good when done, IMO.
-Stroke
Wow, that looks good!
https://www.corvetteforum.com/forums...-bb-build.html
Question, it seems there is a lot of space to fill in between the fender and flare in order to get them bonded. I don’t see really any flat areas other than the clecko spots where the flare mates against the fender. Did you just fill all that space with VPA?
-Stroke
-Stroke
http://www.evercoat.com/fiberglass-resins/us/
After you get it close, you can then use some body filler for final smoothing.
