Plug wires
Old May 2, 2019 | 06:12 PM
540 vette's Avatar
540 vette
Default Plug wires
I am in need of some plug wires and am curious to what you guys are using. The motor is a ZZ502. I am putting on a Sniper gfuel injection unit and using the Sniper distributor and ignition system.
Old May 2, 2019 | 06:30 PM
blue427's Avatar
blue427
I use the Accel ceramic so there's burning of the wires when you have headers. Mike
Old May 3, 2019 | 08:28 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I don't have any issues with my many years old 8 mm Taylor spiro pro wires.
Old May 3, 2019 | 09:32 AM
Street Rat's Avatar
Street Rat
Moroso Ultra 40s
Old May 3, 2019 | 09:40 AM
gkull's Avatar
gkull
https://www.summitracing.com/parts/tay-79602/
Old May 3, 2019 | 10:18 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Pretty easy to cut and make your own plug wire. Buy the wire by the spool and connectors in bulk. When you trim the wire you just need enough to lay back under the terminal connector and crimp it down on top. Sounds to simple but that's how they come from the factory.
Good luck.
Old May 3, 2019 | 10:53 AM
jackson's Avatar
jackson
Seems Dist & SEPARATE Coil Both require HEI type terminals
Big Block
Headers or Manifolds?
Over or Under?
Old May 3, 2019 | 12:11 PM
540 vette's Avatar
540 vette
Big Block
Over or Under?
502, headers, I don't know how I want to run them. I want a set to make my own length.
Old May 3, 2019 | 12:38 PM
jackson's Avatar
jackson
If you can use straight plug boots with your headers, these are spiral & build your own ... a super closeout deal
https://www.holley.com/products/igni...s/parts/257040
Old May 3, 2019 | 01:32 PM
TimAT's Avatar
TimAT
I got tired of trying to keep the plug boots from cooking. And I tried everything out there, including some aircraft stuff. Nothing worked. Just not enough space between the header tube and the plug boots.
To Plug wires
