Vacuum booster
Old May 2, 2019 | 08:27 PM
Gordonm's Avatar
Gordonm
Default Vacuum booster
So I removed the Hydroboost and put a brand new GM AC Delco vacuum booster on the car. I bought it from Eckler since they were having a sale a while back. Now I am finally running the LS motor and getting things dialed in. The brake booster I feel is crap. When. I depress the pedal it moves about an inch with a clunk and then I hear a vacuum leak while the pedal is depressed .When I let go it does not come back fully up. I fear this unit is crap. I usually don’t deal with Ecklers because their returns are usually denied. I will try but now looking for a good aftermarket unit. Not looking for bargain basement but also don’t want to drop a ton on this. What are you guys running. The car has Wilwoods on all 4 corners with a WIlwood MC.
Old May 3, 2019 | 08:31 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Mine is still in the box, but I got it from Corvette SS brakes. They also make a nice tool to make sure your booster to master cylinder rod is adjusted properly. Here are the links:
Booster
http://www.cssbinc.com/1968-76corvet...ter338906.aspx
Tool
http://www.cssbinc.com/1968-76corvet...tmenttool.aspx
Old May 3, 2019 | 11:51 AM
MelWff's Avatar
MelWff
I would buy that adjustment tool before investing in anything else.
Old May 3, 2019 | 12:00 PM
jim-81's Avatar
jim-81
I went with this one from Tuff Stuff https://www.summitracing.com/parts/tff-2129nb
So far so good.
Old May 3, 2019 | 12:28 PM
Gordonm's Avatar
Gordonm
It came with the booster. It was actually adjusted correctly.
Old May 3, 2019 | 01:22 PM
OldCarBum's Avatar
OldCarBum
I would give Wilwood a call and ask them which one works best with their system.
Old May 3, 2019 | 04:54 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
So far so good.
TuffStuff here also. No issues.
Btw, why are you replacing the hydroboost?
Old May 3, 2019 | 07:28 PM
Gordonm's Avatar
Gordonm
Didn't like it. It was not a linear feel when braking. I actually like the manual brakes on my Cobra the best of all. Takes a slight bit more effort but you always know where you are in braking. Just my opinion. Its not for everyone.
Old May 4, 2019 | 12:03 PM
MelWff's Avatar
MelWff
did you bench bleed the master before installing it?
how much pedal movement with the engine off after you bleed off the vacuum by repeated pumping?
Old May 4, 2019 | 01:25 PM
Gordonm's Avatar
Gordonm
Yes I did. Actually not much movement once I can feel it "engage". The brake part of it works fine. I have plenty of good pedal. It is something in the booster. I hear it hissing at me when the brakes are applied. When I release it the hiss goes away.
Old May 5, 2019 | 03:19 PM
Crimson Thunder's Avatar
Crimson Thunder
I actually love the non-power brakes on my Corvette. Just a new Delco master cylinder, Vette Brakes o-ring calipers and whatever pads they shipped with them. The pedal has a great feel and the car has smooth confident stops.
Old May 10, 2019 | 08:26 AM
Gordonm's Avatar
Gordonm
Just a quick update. I went ahead and bought another booster. This one was from Tuff Stuff. Took it out of the box and right aways started to move the shaft in and out. Feels much better. I hooked up my vacuum pump. Sucked out the air and it held 5 in of vacuum for 5 minutes. Tested the brand new AC Delco from Ecklers and it dropped 2 inches of vacuum the first 2 minutes. Obviously something wrong with this unit. Removed it and installed the Tuff Stuff one after checking all the clearances and adjustments. No more clunking when the pedal is depressed and all seems much better. Still waiting on a part for the motor to fire it up and check it under full vacuum. So it seems like the 3rd time is a good booster. 1 rebuilt unit that looks like crap, 1 brand new AC Delco worked like crap and finally the Tuff Stuff one looks to be the ticket.
Old May 10, 2019 | 09:12 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
My TS booster will hold a vacuum for days.
Old May 10, 2019 | 06:06 PM
Street Rat's Avatar
Street Rat
You must be EXTREMELY well versed with getting to those four booster attachment nuts.
I feel for you.
Glad you are on the right path now.
Craig
Old May 10, 2019 | 06:45 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Gordo, I to went with the Wilwood brakes and master cylinder on my Blue Dart 541 69. I added a vacuum pump to supplement the low engine vacuum on that engine. (9-10 in/HG) I plumbed the lines so the engine or'd with the pump got the original stock booster and the surge tank to ~ 20 in/Hg before pump shuts down. The vacuum switch will turn it back on around 16inHg. Holds vacuum for a long time or until I step on brakes and pump has to catch system back up. This does not happen immediately as you can imagine. Brakes work fine at >15 in Hg, but lousy below that (i.e. 9-10 inHg) Stepping on brakes saps vacuum back to engine levels. Is this normal for these old boosters? The engines with high vacuum have a much faster recovery I'm sure. Plan to call Wilwood and ask about dual diaphragm options wondering if that would be more vacuum efficient???
Anyone with knowledge in this area?
P.S. I put the rest of the vacuum system behind a switch which I can control from cockpit. Trying to keep the headlights, wiper door, A/C system from contributing slow leaks is a mountain to tall. LOL
To Vacuum booster
