Intermittent tick in the engine
Old May 3, 2019 | 09:48 AM
Dusky's Avatar
Dusky
Default Intermittent tick in the engine
Hi guys!
Not my car, but a friends car.
He has an intermittent tick in his engine. Almost like a valve that's ticking/ collapsed lifter but intermittent.
Sometimes it happens as soon as he starts the car, sometimes it happens after only 5 minutes running, sometimes after 45 minutes.
Once he gets out the car, opens the hood and start's looking for the noise it sometimes already has dissapeared.
He's quite experienced with cars as well, and puzzled as to what's causing this noise.
Anything that springs to mind? Already checked for exhaust leaks as well. As the exhaust valve on the passenger side, EGR valve disabled to test, valves checked,double and triple checked,...
The key to the answer gets a price!
Old May 3, 2019 | 10:19 AM
jackson's Avatar
jackson
Are ALL lifters noisy? Several? Just one?
Is oil pressure both correct & steady at ALL times?
Old May 3, 2019 | 10:28 AM
Dusky's Avatar
Dusky
IF it's a lifter, it's only one then.
Somwhere around the passenger side near the bulkhead.
Oil pressure is steady, 2.5 bar idle (36 psi)
Old May 3, 2019 | 11:37 AM
REELAV8R's Avatar
REELAV8R
Intermittent issues are always hard to find unless you can catch it failed.
to me it sounds like a lifter that is collapsing intermittently. I had an old Subaru that would do that. Fine most of the time and clacking away at other times. Replaced lifters and that fixed it.
either he’ll have to wait until it’s constant or get lucky to catch it. Otherwise replacing lifters would be the only way to eliminate them as a cause. Flat tappet lifters? At least they are cheaper.
Old May 3, 2019 | 12:21 PM
L-46man's Avatar
L-46man
While I'm not a big fan of 'magic lotions'...here is one that really does work.
For collapsed lifters and more importantly partially blocked or coked up lifters....A really good dose of MARVEL MYSTERY OIL can sometimes clear the blockage.
Doesn't hurt anything else.
This may take 500 miles to work.
May I assume that the car sits around and then is used, then sits...rinse and repeat.
Unkahal
Old May 3, 2019 | 12:46 PM
jackson's Avatar
jackson
Marvel worth a try.
Old May 3, 2019 | 07:39 PM
cv67's Avatar
cv67
St. Jude Donor '05
What kind of engine? Can you get a YT clip of it?
Had a broken valve spring that would do what you describe, all we can do is guess. Pop a valve cover then start it
Old May 3, 2019 | 08:04 PM
REELAV8R's Avatar
REELAV8R
Originally Posted by jackson
Marvel worth a try.
Ya, what the heck worth a try.
Old May 3, 2019 | 08:36 PM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Could be a broken valve spring.
Old May 3, 2019 | 08:50 PM
Dusky's Avatar
Dusky
He s running some ATF mixed in the oil atm.
Valve covers have been offf and didnt see a broken spring.
I suspect a lifter too, although it sounds a bit different than a lifter when he showed me a video on his phone. Waiting for him to send the sound sample to my email so I can share it here.
Old May 4, 2019 | 07:12 AM
jackson's Avatar
jackson
https://www.corvetteforum.com/forums...-71-350-a.html
This recent thread ... owner chasing noise ... ended up being faulty mechanical fuel pump.
Not saying that applies here ...never know.
Old May 4, 2019 | 09:27 AM
HeadsU.P.'s Avatar
HeadsU.P.
Your best diagnostics right now is, with the valvecovers off, engine off, start grabbing rockerarms. Go right down the line. Bump the IGN key over and check all the rockers again. You are looking for that special one that doesn't play well with others.
(maybe a wiped cam lobe)
To Intermittent tick in the engine
