Cold air induction - anyone have it?
Old Nov 5, 2002 | 02:37 PM
Brettmc's Avatar
Brettmc
Default Cold air induction - anyone have it?
Does anyone have cold air induction using the vette cowl induction hood? Where didja get the stuff to do it with? Did you have to sell your wife or your first-born to do it? If you sold your wife to do this mod, who took her and do ya think they'll take mine in trade too? :lol: :lol:
Old Nov 5, 2002 | 02:58 PM
Todbo's Avatar
Todbo
Default Re: Cold air induction - anyone have it? (Brettmc)
I've got this on my todo list , if you want to try this own your on look at this place for parts ramairbox-dot-com
Old Nov 5, 2002 | 03:54 PM
Matt Gruber's Avatar
Matt Gruber
took me 16 hours to build a plywood box that seals to the hood with pipe insulation. allows me to use 87 octane
Old Nov 5, 2002 | 03:57 PM
Brettmc's Avatar
Brettmc
Default Re: Cold air induction - anyone have it? (Todbo)
I really want a cowl induction setup similar to the L88, chevelle, camaro setups. I think if I get the base and the rubber seal, I'l be good to go.
Old Nov 5, 2002 | 04:33 PM
Chuck Harmon's Avatar
Chuck Harmon
Ecklers has all the parts, but you will have to align and bond the fresh air chamber to the underside of the hood. They do work. for every 7.5 degrees you reduce the air temperature entering the engine, you gain 1% horse power. Without the fresh air, the under-hood temps on a summer's day can hit 200+ degrees. A 100 degree difference can be 12-13%.
Buy an outside thermometer and stick the remote sensor next to your air cleaner to see from the cool comfort of your drivers seat what is baking underneath your hood as you trundle along. You might find more power from other investments than spending $600 to $1000 for a real fresh air hood, but it is a good proven choice. The more powerful the engine, the more important the fresh air becomes. 13% equals about 70hp for my L88. Even more important, it reduces the tendency to knock or ping on less than optimum gas.
Chuck
Old Nov 5, 2002 | 04:45 PM
Brettmc's Avatar
Brettmc
Default Re: Cold air induction - anyone have it? (Chuck Harmon)
I hate heat in the engine compartment. Whenever I get home from a summer ride, I always raise the hood the get air circulating before i go inside. I just can't stand the thought of all those components baking with the hood closed. I've got the cowl hood and assumed the partitions were in place. The lower piece is there. I'll check when I get home.
Old Nov 5, 2002 | 05:02 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Chuck Harmon.
http://temp.corvetteforum.net/c3/the...t/index9.shtml check the bottom of the page.
Old Nov 5, 2002 | 05:48 PM
Xracer's Avatar
Xracer
Chuck
In my Pro Street Camaro, I picked up 3 tenth's in my sixty foot. Yes that is right 3 thenth's by putting a functional cowl hood on the car.
Joe
Old Nov 5, 2002 | 06:35 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Old Nov 5, 2002 | 06:39 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Cold air induction - anyone have it? (yellow 72)
I am using the factory cold air intake on my 1980. It's better than nothing.
Later on, when I have the spare $$$ I am going to put a 1967 "Stinger" style hood on the car and cut open the air intake on that.
Old Nov 5, 2002 | 07:05 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
yellow 72,
I think I may have to take a trip to Cinci next spring/summer to meet you and view your car. I didn't realize you were that close or I would have been out there this summer. I'm only about 4 hours away on the west side of Indiana. I've admired your vette for over a year now. :cheers:
Is there any worry of sucking water down into the cowl if you're caught out in the rain? I try to avoid driving the vette in the rain anyway, but sometimes I get stuck out in it.
[Modified by Captain Morgan, 5:07 PM 11/5/2002]
Old Nov 5, 2002 | 07:16 PM
Tom73's Avatar
Tom73
I must be missing something here, but your 74 came standard with cowl induction. It was on all Vettes from 73-75.
tom...
Old Nov 5, 2002 | 07:33 PM
ericshaw's Avatar
ericshaw
Default Re: Cold air induction - anyone have it? (Xracer)
my 79 Pro Street Monty Carlo + tunnel ram = WHAT HOOD?!! :D
Old Nov 5, 2002 | 09:00 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
:seeya Here's a pic of my version of cold air induction! :yesnod:
Old Nov 5, 2002 | 09:24 PM
shawn_cake's Avatar
shawn_cake
Yes - mine is home-made..
:cheers: :cheers:
[Modified by shawn_cake, 6:24 PM 11/5/2002]
Old Nov 6, 2002 | 04:06 AM
zwede's Avatar
zwede
Got all the parts from Gary Gruhala.
Old Nov 6, 2002 | 06:06 AM
1979toy's Avatar
1979toy
I've got a functional L-88 hood from J.C. Whitney and carb parts from Paragon. Check out MDSmith's site to see what I copied. http://www.corvetteforum.net/c3/mdsmith/l88.htm
To Cold air induction - anyone have it?
Old Nov 6, 2002 | 09:26 AM
Brettmc's Avatar
Brettmc
Default Re: Cold air induction - anyone have it? (Tom73)
Tom73 - My car is far from the way it was when it left the factory. I do have the factory cowl hood and want to seal the carb to the hood. I think I need just the base and rubber gasket. My 14"X3" K&N and present air cleaner lid should fit. Am I right or am I missing something?
Very slick L88 air setups, guys! :yesnod:
Old Nov 6, 2002 | 02:37 PM
Tom73's Avatar
Tom73
The factory assembly consisted of the base, a flange (that the seal fastened to), and the rubber seal. I would watch ebay for the base and flange. A rubber seal is available from most Vette vendors but it is usualy the Camaro seal which is slightly too large for the Vette. Dr Rebuid did carry the correct seal but I understand that he is sold out of those now. I picked up mine from a vendor at Bloomington and if I can find that name I will post it.
tom...
Old Nov 6, 2002 | 04:29 PM
GWilliam's Avatar
GWilliam
You may want to check out this site....
http://www.ramairbox.com
I've got a complete cold air cowl induction unit from for @ $150 for my 68
Gary
