a question.... 327's
Old Nov 5, 2002 | 03:59 PM
ZD75blue's Avatar
ZD75blue
Default a question.... 327's
Hi guys, me again...
Can you sleeve a 350 down to 327? i'm just pondering something.
And... anyone have any links to those sb chevy powered Corvairs? (That's what i'm pondering, and no it wouldnt get the vettes engine :nono: )
Old Nov 5, 2002 | 04:25 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Default Re: a question.... 327's
The 327 and 350 cubic inch Chevy engines both used a 4.00" bore... No need to sleeve anything. The difference in displacement was due to the crank stroke (although there are journal differences to deal with). For a street engine, I can't see any advantage to reducing the displacement... Go with the 350.
And... anyone have any links to those sb chevy powered Corvairs? (That's what i'm pondering, and no it wouldnt get the vettes engine.
A company by the name of Crown used to make a conversion kit for the Corvairs, although I haven't seen one for sale in ages. I'd get in touch with CORSA, which is a Corvair owners organization... I would imagine that one of their members could point you in the right direction.
Good luck with your project!
Regards,
Old Nov 5, 2002 | 04:41 PM
ZD75blue's Avatar
ZD75blue
Default Re: a question.... 327's (Rowdy Rat)
doh... i should have known that... :crazy: :smash:
Old Nov 5, 2002 | 04:56 PM
Wrencher's Avatar
Wrencher
Default Re: a question.... 327's (ZD75blue)
The 327 large journal crank (fits a 350 block) is a rare, expensive beast. If you want a revver, thats the ticket, because you can use the 4 bolt block and make a stout lower end.
As for the mid-engine 'vair, get in touch with Clark's Corvairs on the East Coast. They have the kits in stock, but they may also have a line on a car that has already been cut up. Gotta tell ya, these are the ultimate sleepers. Guy at Sears Point has one that is well diguised, running a 400 small block that just terrorizes the coast road. Good luck.
Hans
Old Nov 5, 2002 | 06:11 PM
ZD75blue's Avatar
ZD75blue
Default Re: a question.... 327's (Wrencher)
one more q... how much would a full roll bar and tube frame for a vair weigh?
... trying to overcome some saftey issues... :jester
Old Nov 5, 2002 | 06:49 PM
Schmucker's Avatar
Schmucker
Hans
Hmm, what about my dad's large journal 302 crank? I wonder how that would work in a 350... :D
Old Nov 5, 2002 | 07:32 PM
Wrencher's Avatar
Wrencher
The Corvair coupe unibody is pretty rigid and you put a full cage in it with struts out to the suspension pickup points it'll be rock solid. With the V-8 you give up a cross-bar, but the rear tube frame makes up for it. As long as you use a '65 or later, the "safety" issues are not a problem. What rear gear assembly 'ya considering?
Hans
To a question.... 327's
